It is currently Wed Oct 28, 2026 3:49 am
 Post subject: Air filter box
PostPosted: Mon Apr 08, 2013 9:30 am
This is going to be a stupid question but here goes. I am trying to get the air filter box off. I have removed the 4 plastic grommets in the top which should allow me to get at the nuts inide the air filter box. Unfortunately the air filter horn which has cutaways presumably to let a socket in and the nut out encroaches to the edge of the nut. This negates the usefullness of the cutaways as I can neither get a spanner in or the nut out. Has anyone else had this problem and if so what is the solution.
 Post subject: Re: Air filter box
PostPosted: Mon Apr 08, 2013 9:40 am
loosen all nuts and then lift the airhorn to get the nuts from the thread rods.
As the problem is mainly with the rear nuts I grinded the cutout corners of the air horn a bit more to get a tube spanner on and the nuts off.
PostPosted: Mon Apr 08, 2013 11:18 am
I think for future removal I will grind the airhorn but at the moment I can not get a spanner on the nuts at the back and only barely on the two at the front.
PostPosted: Mon Apr 08, 2013 1:24 pm
Finally got them off with the aid of a pair of needle nosed pliers. Just got to grind the corners of the air horn before I refit it and that will make life so much easier if ever I need to do this again :)
PostPosted: Mon Apr 08, 2013 11:55 pm
Mine was fairly tight clearance wise but I used a 1/4 " drive socket ok . You really need 6" inch long double jointed fingers to get the rear ( front ) nuts on . Don't just stick them into the end of the socket and lower them thru the airbox top ...... they WILL fall out and go down the carb ( that never happened to me :mad: :mad: )
PostPosted: Tue Apr 09, 2013 7:05 am
Mine wasn't helped by the fact that there were spacers, which may have been fitted by a previous owner as they were different lengths, on the threaded rods from the carburettor which brought the nuts right into the cutaway on the air horn. If they had been lower (which they will be soon) I could have got a long thin socket onto the nut a lot easier.
You are of course right as that carb mouth is just asking for all sorts of bits and pieces to be posted in there. :D
