ducatipaso.org • View topic - New Design Timing Belts. What do you Think?
It is currently Wed Oct 28, 2026 12:36 pm
 Post subject: New Design Timing Belts. What do you Think?
PostPosted: Mon Apr 22, 2013 10:01 pm
I just got these new belts from Bevel Heaven made by an Italian company named Bucci. They are Kevlar and are for various Ducatis, including the 907ie.
https://store.bevelheaven.com/engine-re ... down-menu/
When I got them, they have wedge shaped teeth. Our bikes usually have rounded teeth, 70 teeth per belt. I talked to the guys at Bevel Heaven and he said that Bucci has a patented design with these teeth that make them work on Ducatis that use the round tooth belts or the wedge shaped teeth, these belts have 70 teeth. I have enclosed a picture, take a look and see what you think.
The old or original belt is on the outside, the new design belt is on the inside of the bend.
See those 2 points at the end of the teeth. There is some other "textures" on the teeth that doesn't show but apparently this is their patented technology.
 Post subject: Re: New Design Timing Belts. What do you Think?
PostPosted: Mon Apr 22, 2013 11:35 pm
Bucci belts are some of the best and always have been
PostPosted: Tue Apr 23, 2013 5:10 am
PostPosted: Tue Apr 23, 2013 9:25 am
They are not much cheaper than oe(price is each belt?). Do they still need changing every 2 years?
PostPosted: Tue Apr 23, 2013 11:33 am
Nice.
IMO the Kevlar is just as, if not more important, than the shape of the teeth.
Thanks for the heads-up! :thumbup:
PostPosted: Fri Mar 06, 2015 8:34 am
Those BH belts have similar tooth to Dayco belts, with a 'groove' at the tip of the tooth.
