ducatipaso.org • View topic - left hand fuel cock/pet cock
It is currently Thu Feb 26, 2026 6:29 pm
 Post subject: left hand fuel cock/pet cock
PostPosted: Sat May 03, 2008 11:11 am
In the process of cleaning the tank on my 750 Paso I lost my fuel cock - dumb move - Has anyone had any luck finding OEM on substitute fuel cock? On http://www.pingelonline.com has a model # 6311 cr round valve - does anyone know if that model will work? :banghead:
 Post subject: Re: left hand fuel cock/pet cock
PostPosted: Sat May 03, 2008 6:41 pm
If your located in north america I would suggest Columbia Car and Cycle in Nakusp, B.C. Although Wolfgang Haerter is a Laverda specialist, he has lots of generic Italian parts. You can call him at 250-265-4502. I bought one for my paso from him 2 weeks ago and it was $20. I asked for a left fuel tap with the outlet facing forward and it had a black plastic lever which was lucky because I had to trim 1/2 the lever off so I could turn it once it was installed (to clear the sloping frame rail)
Hope this helps.
R.L.
PostPosted: Sun May 04, 2008 2:04 pm
RL,
Actually your info helps quite a bit, I wound up ordering a Paioli from Bevel Heaven and it sounds very similar to what you have - Do you know if the part you got was a Paioli?
GC
PostPosted: Mon Apr 01, 2013 5:05 pm
Does anyone know - will a 900SS fuel cock # 58840051A replace the original Paso 750 fuel cock # 000045184?
PostPosted: Tue Apr 02, 2013 3:39 pm
I hope the link above directs you to what is available and what you are looking for.
Best regards and good luck
PostPosted: Thu Apr 25, 2013 4:53 pm
PostPosted: Fri Apr 26, 2013 10:33 pm
Can you let us know how the plastic gasket works out? At least it looks plastic on their website photo. The fiber gasket on mine is shot and Bevel Heaven set me up with a plastic gasket of similar dimensions which looks a lot like the one on the website photo.
PostPosted: Wed May 01, 2013 8:30 pm
whitepaso,
I received the fuel cocks today 5/1/2013, the part number listed on the package is #800045184 the description is 750 Paso M12x1.
Unfortunately it’s the wrong part. The fastener nut size is smaller then what’s required to fit my gas tank.
I compared it to Ducati part number #58840051A for a 900ss it’s the same size as the ss part. Not good for me!!
To comment on the plastic or nylon gasket it’s made of a heavy material and it appears as if would be an adequate replacement for fiber.
PostPosted: Thu May 02, 2013 12:01 am
PostPosted: Tue May 07, 2013 12:29 am
That's a disappointing delivery! I think the thread size is 16mm on the tank, if that helps. Keep us posted on what you come up with.
