ducatipaso.org • View topic - Offset keys .. cam pulley's
It is currently Fri Feb 27, 2026 9:53 pm
 Post subject: Offset keys .. cam pulley's
PostPosted: Thu May 02, 2013 4:54 am
Anybody got a hot tip as to who could supply me some offset keys . I have struck out locally ( no bastard could be bothered even returning my e-mails ) and uncle Ian ( Gowanloch ) hasn't replied either . Im pickin that someone either in Aus or the US will know someone .
Hamish
 Post subject: Re: Offset keys .. cam pulley's
PostPosted: Thu May 02, 2013 8:35 am
Hamish
I got mine from Brad Black in Melbourne. I took them out when I got a set of adjustable pulleys, still have them in a box somewhere. From memory one was 5 deg and the other 6 deg. I don't need them any more.
What size are you after?
PostPosted: Thu May 02, 2013 10:19 pm
I need 4 and 8 deg as my lobe centers are at 111 deg and 114 deg . The thinking being that I can fit both and get 106/107 deg lobe centers , or just fit the 4 deg one and have 110/111 deg lobe centers. One thing bugs me is that I get 270 deg duration on the vert cyl and 272 on the horiz cyl. I have done the measurements several times and checked the method heaps ( zero lash , correct TDC , duration at 40 thou valve lift)..... beats me :wacko:
I would rather have adjustable pulleys but they aint as easy to find as you'd think . Epicycle will modify my own pulleys if I send em over the ditch , not sure I can be bothered with that tho.
Hamish
PostPosted: Fri May 03, 2013 2:54 am
PostPosted: Fri May 03, 2013 5:50 am
Hey Hamish,
how about a pictorial on what you're doing.I don't know shit about timing so I might learn something.
Andrew
PostPosted: Fri May 03, 2013 6:06 am
Yeah , Ok ( always fancied myself as a movie star ) , when these keys get here I will sort it out on camera
( Warning , contents may contain low level violence and offensive language )
PostPosted: Fri May 03, 2013 9:42 am
PostPosted: Sun May 05, 2013 10:45 pm
