It is currently Thu Apr 30, 2026 10:48 pm
 Post subject: Ok I surrender how do you get the fuel pump out
PostPosted: Sat May 04, 2013 2:26 pm
Right someone's got to have done this before on here.
How the hell did you get to the 3 nuts at the seat end of the fuel pump flange?
 Post subject: Re: Ok I surrender how do you get the fuel pump out
PostPosted: Sat May 04, 2013 11:00 pm
going by memory, I think the whole plastic ass that holds the fuel pump unclips, its secured by two lugs, one on each side, squeeze in and them lift the whole assembly...then again my memory is not the best lately :-P
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Mon May 06, 2013 7:55 am
Hi duc750,
the whole assembly is holded by 2 clips/springs, but it is a PITA to remove as the clips are strong and more or less bonded to the sleeve holding the pump.
A long time ago I had mine removed for a spray job, but I still remember the fight.
putting in is a little easier if you use a kind of grease to lube the boot on the place where the clips will come.
succes,
Bertus
