ducatipaso.org • View topic - 750 paseo dead
It is currently Thu Oct 29, 2026 1:39 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: 750 paseo dead
PostPosted: Mon Mar 04, 2013 12:38 am
PostPosted: Sat Apr 27, 2013 8:12 pm
Hello again, after 1 month I had some time to work on the bike and found out that is the electric starter motor that does not work. Now the question are, considering never did before...how difficult is to replace the electric starter motor? I saw you can get some on ebay that will fit the Paso for around 200-250 dollars, base on the service manual that I have, looks like need to remove the other side engine panel to access to the mounting screws, do you nee to drain the motor oil first? Is this something that will require some major expertise? should I try? or should just have the bike running somehow a ride to the mechanic?
Thanks, Sal
PostPosted: Sun Apr 28, 2013 12:51 am
PostPosted: Sun Apr 28, 2013 6:13 pm
Thanks!, is there a easy way to open just the back of the starter and check/replace the brushes!
PostPosted: Sun Apr 28, 2013 6:27 pm
PostPosted: Mon Apr 29, 2013 8:05 am
You can find a electric starter motor from another Ducati (SS, Monster, etc). Is the same motor. In my Paso I have one from a Monster. You must change the little pinion of the axle. :thumbup:
70 hp. can change the world
PostPosted: Mon Apr 29, 2013 10:08 pm
Sestese,
There are brush replacement kits available, you get new brushes with the tails and some new springs.
You can get the starter motor brushes out/off without removing the engine cover, but putting the brushes on and refitting the starter is nearly impossible with the engine cover on, it is easier to take the cover off and give yourself some proper access.
Fraser.
750 Paso
1980 Moto Morini 500 Sport
2013 Yamaha MT-01
PostPosted: Tue Apr 30, 2013 3:37 pm
ok, thanks guys.
I'll try this week end and let you know the progress.
PostPosted: Fri May 03, 2013 10:13 pm
Hello, today I started to work on the bike and looks like is very difficult to remove the end cap of the starter motor because of the 2 oil pressure lines on the way, I was able to remove only one screw...
the other option about opening the left engine cover sounds better,...I think, not sure. Do I need to drain the motor oil first opening the side panel? I started to loose/remove some screws and saw some oil drips from the bottom. ..Please help!
Anybody on the forum live in Los Angeles area so I can chat for some help?
Thanks.
PostPosted: Sun May 05, 2013 5:22 pm
To open the back of the starter to inspect the brushes, I did move the two oil lines out of the way, but I had to modify a spanner to do so for clearance purposes. I believe I had to grind down the width of the open end wrench in order for it to be thin enough to slip into position around the fittings. it was not difficult. The hard part was putting to rear cap of the starter back on with the brushes in the correct positions. Best of luck!
PostPosted: Sun May 05, 2013 6:33 pm
ok, thank you very much!
I'll try to remove the oil lines and see if I can just change the brushes.
PostPosted: Sun May 05, 2013 11:00 pm
When I removed the starter off my SS ( pretty much the same set up ) I removed the cable 1st and then leaned the bike over against the work bench for 1/2 hour ( to let as much oil as possible to drain out of that cover area )_ and removed the left cover . If you remove the oil pipes to the cooler you will need to contain the oil and ( for me ) I wanted to do the job without getting messy
Hamish
