ducatipaso.org • View topic - Crashed the 906
It is currently Wed Oct 28, 2026 1:48 am
 Post subject: Crashed the 906
PostPosted: Sun May 05, 2013 10:10 am
Blow! Ran into the back of a 5 car pile up on the motorway. It was in the left lane (we drive on the left side here in Australia) and tried to get around to the left but, dang it, the car in front pulled to the left with the same idea. The bike bounced off car's bumper and I went rolling on down the motorway shoulder ending up sitting in a bush.
Took off all the crushed head light, instrument panel and radiator and I can see the frame on the right front side is bent where the light sub-frame is attached.
I'll try ringing Metropolitan Motorcyles here in Australia as they have some ducati parts - to see if they have a frame - you never know your luck. Tank is stuffed too. Fairings were not on at the time - that is my bit of luck.
Not sure whether I can get it back, pondering the options.
 Post subject: Re: Crashed the 906
PostPosted: Sun May 05, 2013 2:01 pm
Bad Luck there Romus.
I see frames on ebay all the time for cheap. I can most likely cut out the section you need from my spare if you know a good welder.
Most of the other parts can be had relatively cheap
PostPosted: Sun May 05, 2013 10:54 pm
Yeah , what a bugger , sounds like your ok which I spose is the main thing ,( being an Aussie in all :) :D ). How does liability go for that ? Did the driver of the car indicate before pulling onto the shoulder?, or even look ? . Im assuming that if you didn't have the fairings on then you also had no front indicators , possibly meaning that your bike was not in a roadworthy condition . Got any pix :) :) :)
PostPosted: Mon May 06, 2013 10:49 am
 Post subject: Crashed the 906 pics
PostPosted: Mon May 06, 2013 1:18 pm
I didn't get a pic of the smashed front before I took things off.
Here are the smashed bits:
The bent part of the frame seems caused because the welded Stop on the frame was missing/dropped off some time!!!
Looks to me that a bend at that place is difficult to fix bacause it is near a cluster joint. There are some frames on ebay but not in Australia and the freight eg from the UK would be too much. No luck yet locating a frame here in Australia.
PostPosted: Mon May 06, 2013 6:51 pm
You're lucky to be survived!!!
And you've been doubly lucky to have had the fairing out!!!!!
I think you'll manage to restore the bike to the former glory.
All the bits often pop up on ebay at some reasonable prices and if something will lack, you could ask it here.
Good luck :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Mon May 06, 2013 11:21 pm
Don't "think I have a fairing stay" But I can cut the entire neck form my spare no problem. I most likely have all you need except the stay but as you state shipping is the issue
let me know
PostPosted: Mon May 06, 2013 11:26 pm
200 lb bike
PostPosted: Tue May 07, 2013 10:25 am
sorry to ear about your mishap there romus, when the dust settles, hopefuly you will decide to rebuild the bike, good luck. :(
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Tue May 07, 2013 12:51 pm
PostPosted: Tue May 07, 2013 3:25 pm
sorry to hear the bad news, if you do rebuild I have a 750 paso quite a few bits I used the motor in a racer,
Just sold a mirror to aus, dont want a lot for anything thats left if it helps.
PostPosted: Sat May 11, 2013 9:33 am
Romus, I`m off for a few days and your news is one of the first things I have to read. :? We`re all glad you were lucky!!! Too bad for the bike.
If the steering stops are ok is one of the things to check when buying a Paso. If they are bent, broken, there`s a crack or an adjustment screw in the lower triple clamp was replaced by a longer one the bike has seen the ground in the past. Then most likely one bar end is scratched and there`s a small dent on the tank near the DUCATI sticker as well.
The steering stops are not that simple to reweld as that`s the area of the lower steering bearing so this has to be kept cool while welding.
I`m sure there`s a shop that can straighten and measure the frame. This would be the starting point for a bottom up restoration.
All the small bits are not the problem. Make us a list of what you need and I`m sure we can source them.
Is the fork still straight ?
PostPosted: Sat May 11, 2013 11:22 am
there are a few shops around you (as you probably know)
http://www.motorcyclestraightening.com
http://www.simca.com.au/
http://niccomengineering.com.au/
http://www.streetfighters.com.au/forum/ ... ngineering
PostPosted: Sat May 11, 2013 8:13 pm
sorry you crashed your bike man, those low speed collisions are so annoying. glad to see you are ok and taking it on the chin. get her fixed up if you can. :cool:
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
PostPosted: Sun May 12, 2013 9:57 am
