ducatipaso.org • View topic - D@mnit!! Mirror replacement.....just the mirror glass.
It is currently Mon Mar 09, 2026 1:44 pm
 Post subject: D@mnit!! Mirror replacement.....just the mirror glass.
PostPosted: Tue Apr 30, 2013 4:19 am
Anybody know where my dumb@ss can get a new piece of mirror glass to replace the piece I just dropped? :mad:
 Post subject: Re: D@mnit!! Mirror replacement.....just the mirror glass.
PostPosted: Tue Apr 30, 2013 4:48 am
Ha ha ( Nelson Muntz ) I just had a measure up and mine are about 98mm for the actual mirror so I figure that they are a 100mm or 4" in diameter mirror . Why not go get a ( not to ) cheap 4" mirror and take the glass out of it. The ole Paso mirrors , the glass is set into a plastic insert , with the swivel bit on the back , and the whole thing is held in by 1 screw that hides behind the blinker reflector . dig the broken glass out ( practice w/shop safety , its no fun having sharp implements removed from your body ) and using a couple of blobs of silicone sealer stick the new bit of glass in. I can post some pix if you want as I just happen to have a mirror in bits in preparation for painting. :)
Hamish
PostPosted: Tue Apr 30, 2013 5:13 am
Yeah, I had my blinkers apart a few weeks ago and had taken the screw and the mirror out. I then placed the mirror back into the blinker assembly, without replacing the screw, and set it on the workbench. When I picked it up today to re-assemble everything the mirror fell to the ground, shattering the glass. Luckily, the whole thing popped out of the plastic insert. No digging required. Yay for me!?!?
PostPosted: Tue Apr 30, 2013 2:45 pm
Yeah, one of mine shattered a while ago - at least 9 years ago, now that I think about it - and I just measured the good one and had a local glass shop cut me a new one. 100mm/4" is what I used too. I don't think it cost me $5 and haven't had a problem since.
1988 Paso 750 #753965
1997 Monster 750
PostPosted: Fri May 03, 2013 10:17 pm
Let me know if you still need a mirror. I may have an extra one in my broken parts bin. How do you get the mirror out of the housing?
PostPosted: Fri May 03, 2013 10:26 pm
carefully,its double sided tape
PostPosted: Sat May 04, 2013 1:59 am
PostPosted: Wed May 08, 2013 2:37 pm
Sorry Jason,
I have been searching for that mirror but am unable to find it. I moved here about 10 months ago and am still unpacking boxes. I will let you know if I find it but it's not looking good.
Sorry,
Jeffreyt
PostPosted: Wed May 08, 2013 3:50 pm
i might be wrong but i think a morris minor glass is the same size?
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
PostPosted: Wed May 08, 2013 5:20 pm
No problem....I really appreciate you even looking at all! Thanks!
I did stop by a craft store yesterday and found a couple of 4" round mirrors for <$3. They are a little thicker but I am going to try one out and see how it works. I will let you know.
PostPosted: Wed May 08, 2013 5:21 pm
PostPosted: Wed May 08, 2013 5:28 pm
Morris Minor
PostPosted: Fri May 10, 2013 5:46 am
a very nice example :cool: :cool: :cool:
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
PostPosted: Fri May 10, 2013 8:31 am
PostPosted: Sat May 11, 2013 8:53 am
Woooooow!!!!
I love her!!!!!!
Ciao :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
