ducatipaso.org • View topic - getting horns to work
It is currently Tue Oct 27, 2026 2:32 am
 Post subject: getting horns to work
PostPosted: Tue May 21, 2013 12:13 pm
Anyone have a suggestion on getting more power to the horn(s)? I removed one horn hoping to get the remaining one to work but it just groans a bit. It works great when jumped directly to the battery. I have cleaned all contacts and replaced some of the wires, the ones that go to the horn directly. Any suggestions?
Jeffreyt
1987 Paso
 Post subject: Re: getting horns to work
PostPosted: Tue May 21, 2013 7:00 pm
Put in a relay.
That's how it is in almost any car, and most motorcycles.
PostPosted: Wed May 22, 2013 6:23 am
Some horns have a small screw on the back of them that can be tweeked to "tune " the horn , but if yours goes ok when wired to the battery ckeck that it is earthed properly and also check the voltage to the horn , if there is not enough volts you are better off finding the problem and sorting it than just chucking a relay at it , which may well get the horn going but you are only hiding the problem which may well come back when the relay starts to not work .Having said that I have a relay on mine and there is a BF set of air horns ready to be bolted on ( if I face them directly forwards they will add to the braking in an emergency)....... I once ( when young and impressionable ) had an electric compressor ( 120 psi ) , a pressure tank ( old Freon cylinder ) , electric air valve and 4 sets ( 12 horns ) of horns on my car , scared the shit outa heaps of people but then the cops made me dismantle them on the side of the road...... good times :D :lol: :lol: :lol:
PostPosted: Thu May 23, 2013 12:19 am
Thanks for the two horny guys. I'll look into the relay but I think the problem may be in the switch.
PostPosted: Thu May 23, 2013 3:23 am
PostPosted: Thu Jun 20, 2013 2:15 am
I "fixed" mine with one of :
Much louder than the stocker and fits right in the same place. Liked it so much I put one my Monster too, and that one was working fine ...
1988 Paso 750 #753965
1997 Monster 750
PostPosted: Thu Jun 20, 2013 10:35 am
