ducatipaso.org • View topic - Leaking Clutch Fluid ???
It is currently Sun Mar 01, 2026 7:05 am
 Post subject: Leaking Clutch Fluid ???
PostPosted: Sun Nov 13, 2005 5:54 pm
PostPosted: Mon Nov 14, 2005 1:03 am
Donna G
'12 Moto Guzzi V7Racer
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
PostPosted: Mon Nov 14, 2005 12:33 pm
PostPosted: Mon Nov 21, 2005 5:34 am
also check the pressure plate as you may still have the three little ball bearings and cup that the slave presses up against . ducati dont make them anymore they have a different pressure plate with no moving parts on them as the slave has a rotating centre which the pressure plate runs against check that this has not siezed. you may have to replace it as well as the pressure plate. i had do do both and the clutch plates just after i purchased my bike be careful with the clutch basket bolts they can strip very easily.
good luck
Rodney
Users browsing this forum: No registered users and 36 guests
