It is currently Mon Oct 26, 2026 7:49 pm
 Post subject: Which UK grade of brake fluid should I use??
PostPosted: Sat Jun 08, 2013 10:39 am
I need to replace the brake fluid in my 750 Paso but am not sure which brake fluid to use Dot3, Dot4 Dot??? Anyone got advice. Did a very quick search but couldnt see anything
Graeme
1990 750 Paso #754364
2005 BMW 1200RT
 Post subject: Re: Which UK grade of brake fluid should I use??
PostPosted: Sat Jun 08, 2013 11:37 am
hi Graeme, I've used Castrol Dot 4 without any problems, some are less prone to moisture contamination...not sure which.
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Sat Jun 08, 2013 12:02 pm
use DOT4. It`s boiling point is higher.
Also if you look in the owner`s manual it says to use DOT4 ;)
PostPosted: Sat Jun 08, 2013 4:24 pm
Don't use DOT 5. It is not compatible with a system that has use DOT 3 and 4.
PostPosted: Sat Jun 08, 2013 8:16 pm
Thanks for the help Dot4 it is then!
Graeme
2005 BMW 1200RT
Users browsing this forum: No registered users and 26 guests
