ducatipaso.org • View topic - Fuel pump
It is currently Tue Sep 30, 2025 7:39 am
 Post subject: Fuel pump
PostPosted: Wed Nov 09, 2005 6:10 am
Hi folks. My fuel pump died and my mechanic tells me Ducati make them no more.
Can anybody tell me where I can find an equivilant pump? It has been temporarily set up with just gravity feed for now (it is my only transport) but my mechanic tells me I will need to keep the tank over half full. It still runs the weber, by the way.
PostPosted: Mon Nov 14, 2005 2:57 am
Redpaso
PostPosted: Fri Nov 18, 2005 5:19 pm
I think you have two options. 1 visit your local Weber carbureter specialist with the fuel pump and quote the carb type (44DCNF). they should be able to match a new fuel pump. But don't get an injection pump. 2 take the pump apart and rewind the motor windings with equivalent transformer wire. Finally you could berate Ducati to drop their Motogp project and that silly V4 so that they can do a refit run for the Paso series.
PostPosted: Mon Nov 21, 2005 4:21 am
Bwahahaha - Magic suggestion RM.
And thanks for the Gowanloch idea Red.
PostPosted: Mon Nov 21, 2005 11:24 am
Brake late & brake hard,
jomo
Paso 906 Blue
Paso 906 Silver
Bultaco Metralla GT370 Custom
Bultaco Metralla GT250
Bultaco Frontera 250 Mk.9
Suzuki RMX250
PostPosted: Thu Nov 24, 2005 1:26 am
Hi All! I had a pump failure on my 906 as well.....after a quick trip to my local Pep Boys, I fetched a Purolator universal fuel pump that is rated 3-5 psi. I think it was 36 bucks and has been working quite well! Good luck!
 Post subject: fuel pump
PostPosted: Fri Nov 25, 2005 6:36 pm
i live in italy.here u can find quite every spare parts about ducati.if u seek for ducati dealers on web,u can get what u need...if u need i can give u some web adress.
Andrea.
PostPosted: Fri Dec 02, 2005 6:10 pm
PostPosted: Sat Dec 03, 2005 9:43 am
PostPosted: Tue Apr 04, 2006 10:50 am
I made a vacuum pump from a Monster fit. It works... but whit a lot of starting problems after few days not using. Also if the bike was driven at slow speed in the city, the petrol did not go through the pump.... Wise lesson: do not trie... :funny:
After 3000kms I bought an old rusty pump from a scooter, never has been better before...
Richard
PostPosted: Tue Apr 04, 2006 9:56 pm
I have also tested the Monster vacuum pump. After a week without running gas evaporated from the carbs. when the carbs were filled :D , the battery was empty :sad: . The only solution I had found was Start Pilot. Now I use the electric pump.
Alain.
Users browsing this forum: No registered users and 52 guests
