It is currently Tue Apr 28, 2026 3:19 pm
[ 8 posts ] |
| Author |
Magicfinger95
Post subject: a dump from original chip Posted: Sat Jun 22, 2013 12:49 pm |
Joined: Thu Jun 14, 2012 5:21 pm Posts: 2 Location: Austria
Hi to all, I'm searching for a original chip dump from the 907 because i want to try to change my ECU to some newer Marelli ECU. Does anyone of you have sutch a file or know were i can get one?
| Top |
900streetfighter
Post subject: Re: a dump from original chip Posted: Wed Jun 26, 2013 9:25 am |
Joined: Wed Oct 27, 2010 5:52 pm Posts: 364 Location: Essex UK
I have spare standard and baines chips you can borrow for copying. Where are you?
| Top |
Post subject: Re: a dump from original chip Posted: Wed Jun 26, 2013 11:17 am |
| paso grand pooh-bah |
_________________ Gert
907 I.E. -91 M900 -97 MTS 1100s -07
| Top |
Post subject: Re: a dump from original chip Posted: Wed Jun 26, 2013 11:55 am |
that`s the leaner US chip, isn`t it ?
| Top |
persempre907
Post subject: Re: a dump from original chip Posted: Thu Jun 27, 2013 11:01 pm |
Joined: Tue Dec 06, 2005 12:00 am Posts: 3312 Location: Roma, Italia
Yes, it's so.
_________________ Francesco Ducati 907IE 1992 Rosso Ducati 907IE 1993 Nero Moto Guzzi Galletto 1960 Sabbia BMW R Nine t 2019
| Top |
Post subject: Re: a dump from original chip Posted: Thu Jun 27, 2013 11:09 pm |
| Top |
du907
Post subject: Re: a dump from original chip Posted: Mon Jul 01, 2013 2:55 pm |
Joined: Fri Jul 08, 2005 12:00 am Posts: 336 Location: Winston-Salem, N.C. USA
Magicfinger95,
You can have a look at these. I got the "Customchip" from a fellow in the UK. It is what I'm using in my 907 now. I am pleased with it. After setting my TPS, balancing the throttle bodies, air screws, mixture screw in ECU, I needed a chip that was richer than my US chip. This one did the trick for me.(I have aftermarket pipes too). The "DucatiEuro" chip is the standard chip used in the European model. Use them at your own risk. They can at least get you started. I don't know what any of the information in the files are. I had them programmed into a couple of chips and like I said, I'm running my bike on the "customchip" one, have been for years. du907
907customchip.obj 907DucatiEuro.obj
You will need to send me a message on this board with your e-mail and I will send the files to you by e-mail.
| Top |
Magicfinger95
Post subject: Re: a dump from original chip Posted: Mon Jul 01, 2013 10:56 pm |
@900streetfighter : thanks for your offer, I'm from Austria but I don't have any tool to readout an EEPROM either copy it.
Thanks to all other too.. i hope @du907 files will work for me if my adaption works i will post the results.
| Top |
[ 8 posts ] |
Users browsing this forum: No registered users and 13 guests |
