ducatipaso.org • View topic - Rear brake light switch?
It is currently Tue Apr 28, 2026 10:00 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: Rear brake light switch?
PostPosted: Mon Jul 29, 2013 3:24 pm
Thank you paso grand pooh-bah. The washer was stuck to the brake pump. I could not see it on the pump. I see you say not to clamp the brake hose. I went on ducatisuite, and they say to use hose pliers to clamp off pressure to the caliper, when changing the pads, to keep the caliper pistons from coming out further. Why should I not clamp off the hose? Will the hose pliers damage the hose? Just curious.
Regards, Paul
PostPosted: Mon Jul 29, 2013 3:36 pm
PostPosted: Mon Jul 29, 2013 3:48 pm
The only thing I can think of, is he is saying the pressure in the line will cause the pistons to come to come out slightly when you remove it from the disc. I am going to look for some washers tonight on my way home from work. Thank you again for the info.
Regards, paul
