ducatipaso.org • View topic - 750 sport dropped the primary drive sprocket
It is currently Sun Mar 01, 2026 12:00 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: 750 sport dropped the primary drive sprocket
PostPosted: Mon Jul 29, 2013 10:41 pm
Thanks for the lead G my local Ducati store did'nt stock them anyway and would have to order them in.
PostPosted: Tue Jul 30, 2013 5:58 am
A pretty lame dealer that doesn't stock a sprocket retaining plate. A pretty common replaceable item. If you have a Ducati with more than 30k on the clock, you are probably due for one. If you own a Ducati made in 1998, you had best get a new one anyway. Bad batch that year. Too soft. Lots of ST sprockets walked off the job like yours did. Not a lot of Ducatis had high mileage until the STs came out, and suddenly there were guys putting 30k a year on the bikes. Found a few issues in the design.
Cheers, Phil.
PostPosted: Wed Jul 31, 2013 8:17 am
model: other
If you've had no luck yet also try
http://www.motoitalia.com.au/
Dave Ward
or Italspares Jim or Ian
02 6946 2626
Peter
PostPosted: Thu Aug 01, 2013 7:27 pm
Got a box of spare bits from a guy. In it was a front sprocket and a retaining plate. The sprocket looked pretty good, but the retaining plate had about half of the material worn away on the tabs that hold the sprocket on. it was pretty close to failure. Definitely a replaceable item.
PostPosted: Fri Aug 09, 2013 5:16 pm
