ducatipaso.org • View topic - Right side mirror needed
It is currently Thu Oct 29, 2026 11:48 pm
 Post subject: Right side mirror needed
PostPosted: Sun Jul 28, 2013 3:35 am
Yes, a mishap destroyed the right side mirror on my 907ie. Anyone know how to locate one?
Bob--docbob1@msn.com
 Post subject: Re: Right side mirror needed
PostPosted: Sun Jul 28, 2013 6:24 am
There are mirror/ blinker assy's ( new ) on E-bay , unpainted , either single or in pairs ( that's pairs of mirrors .... not tits or sheep :D ) and there are also 2nd hand ones too :)
PostPosted: Sun Jul 28, 2013 7:07 am
Hi Bob,
sorry to hear you cracked a mirror.
try Ebay or Far in Italy. they produce replica's which will do the job.
Bertus
PostPosted: Mon Jul 29, 2013 2:33 am
Thanks guys,
Unfortunately, my mirror is the one with the little clips rather than the studss. They are very difficult to come by.
PostPosted: Mon Jul 29, 2013 4:27 am
fortunately some one has made this handy adaptor..... which comes with every Paso:)
Ditto for your 906 and 750 posts
121144410034 is the # for the E-bay listing
PostPosted: Thu Aug 01, 2013 10:23 pm
US $300.00 !!!!!!! plus postage ????
McTool the cost of those Far mirrors is obscene they must only cost about $52 (US) each to buy direct, sadly though you have to buy them in numbers of 25 plus. :banghead:
PostPosted: Fri Aug 02, 2013 5:21 am
Yeah ! I want a spare set .... but not that bad , still I spose if you gotta have them you would have to cough up, me ... Im eyeing E-bay daily so I you want some you will have to be quicker than me :) . I have seen pix of Paso's where some one has grafted other mirrors/blinkers onto them but I really cant see the point as IMHO they are as fundamental to the Paso as the square frame and the fully enclosing body work, 16's and that weber , I guess if its your only transport needs must. And how badly damaged would they have to be before you couldn't repair them :)
Now that's broken , but still fixable :)
PostPosted: Fri Aug 02, 2013 11:15 am
I got a set of FAR -mirrors directly out of Italian factory in grey primer for € 82 a pair incl. posting/packaging and stuff like that. and once in colour and mounted you have to look closely to see the difference.
yes, the orginal ones with the mounting plate are better in many details. but they become scarce.
I have bought some battered original sets to repair one day. because the mirrors are one of the distinctive PASO parts.
Bertus
PostPosted: Fri Aug 02, 2013 2:54 pm
Hi I have a pair in blue bit scratched on the paint, and 1 more not sure if its right or left.
E Mail duck450scr@hotmail.com
PostPosted: Fri Aug 02, 2013 4:25 pm
Hi McTool,
your leg was definitely broken. did it heel well in such way that you got the most important functionality back?
more or less my mirror looks the same, but still I think it's fixable.
wrecked mirror_4small.jpg [45.49 KiB]
Downloaded 604 times
PostPosted: Fri Aug 02, 2013 9:38 pm
That mirror is a challenge but I bet you could fix it ... just like a jigsaw . I think the thing to do is find the correct adhesive as not all types will work on some plastics , I would go for a polyester rather than epoxy for that .
Leg? nah , 4 years on and Im still having bone grafts that don't quite work , still on crutches , and the orthopaedic guy keeps talkin amputation , I also crushed my foot , ripped my knee apart , busted my hip & pelvis and buggered my sciatic nerve so at its best possible its never going to be great :)
PostPosted: Fri Aug 02, 2013 10:23 pm
we have a glue here in the states called rapid fix
It is a form of superglue and comes with a powdered form of activator
Works on all kinds of plastic as well as lots of other materials and is sandable once dry
I bet it even works on bone :thumbup:
PostPosted: Sat Aug 03, 2013 2:47 pm
PostPosted: Sat Aug 03, 2013 3:05 pm
Polyester resin works just fine. I did fix a couple of mirrors in the past with it.
PostPosted: Sat Aug 03, 2013 11:03 pm
yes polyester works,much harder to sand and takes longer to cure
Rapidfix is very fast and easily shaped and sanded or machined or whatever
I have found on washer bottles that some forms of washer solvent specifically the bug remover variety will in a week or two dissolve it...not sure why
