ducatipaso.org • View topic - The story so far
It is currently Sat Feb 28, 2026 3:15 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: The story so far
PostPosted: Sat Aug 10, 2013 7:13 pm
all grounds need to be bare metal, no paint, no rust bare metal new,old, bare metal and sealed after, silicone, paint anything to keep the moisture at bay :thumbup: Bare metal to the frame or engine...engine assumes you have a good ground to the frame somewhere and to the battery negative terminal, frame and engine
PostPosted: Wed Oct 09, 2013 9:24 am
New digiplex. :thumbup:
Bike is running very well now.
Lane
89 Dark Blue 906 Paso
PostPosted: Fri May 09, 2014 5:47 pm
Stripped bike down today and got busy with a few tasks still on the list.
Changed out coolant for Evans waterless coolant (works well) and will ditch overflow tank once I'm positive I don't need it anymore.
Replaced oil pressure switch with one from a TDi Disco. (Thanks Derek)
Replaced clutch and rear brake lines with braided lines. I was also going to do the front brake lines but the set I bought came from a 750 Paso and are too long for the 906 as they foul on the radiator.
I took the clutch cover off to inspect the bearing on the slave cylinder. I had replaced the original with one from a 900SS and used a rollerskate wheel bearing with modified mushroom pin. After 7500km's it looks like it did the day I put it in and spins freely...works a treat :thumbup:
Then I took it out the front and degreased the f#<k out of it and gave it a good bath while the fairings were removed. This is the cleanest it's ever been so I thought I'd better take a snap of it coz I don't think it'll ever be this clean again :mrgreen:
A couple of things still left on the wish list like floating discs but basically finished now.
Lane
PostPosted: Fri May 09, 2014 9:30 pm
one must love your all red wiring :)
Do invest $30 in crimping pliers for non insulated terminals and some heat shrinking tube. Those plastic insulated terminals are usually only squashed and if you wiggle a wire it will come loose which also indicates the quality of the electrical connection ;)
If you think you`re done you can start replacing rusty bolts, polish the instrument cluster cover...
PostPosted: Sat May 10, 2014 1:41 am
Lane
PostPosted: Sat May 10, 2014 8:17 am
... and I thought you might be colour blind :-P
What do you want to solder ?
PostPosted: Sat May 10, 2014 8:59 am
The relay on the right of the bike has its wires soldered to the spade fittings but I used all my solder on them :( so the one on the left has its fittings crimped. I was going to drip some solder down the neck of the spade fittings that are crimped so as to make sure they don't come loose. I'll do that before I add some heat shrink tubing. :D
Lane
PostPosted: Sat May 10, 2014 9:04 am
...went for a thrash to show it off while it's clean! :mrgreen:
At the local garden centre....
It's running real good and sounds awesome with the Cobra F1's...beer time :beer:
Lane
PostPosted: Mon May 12, 2014 2:12 pm
Very shiny well done. However, the 3 little girls in the picture were clearly unimpressed :)
PostPosted: Mon May 12, 2014 9:20 pm
Upload some of those scenic poses for next years calender
:beer: :beer:
PostPosted: Tue May 13, 2014 4:51 am
Lane
PostPosted: Tue May 13, 2014 8:58 am
model: other
PostPosted: Tue Jun 24, 2014 5:15 am
New seat :D
Lane
PostPosted: Tue Jun 24, 2014 8:36 am
looking good. Now you`re only missing the side reflectors to put on those small plates hanging from the rear inner fender.
PostPosted: Tue Jun 24, 2014 9:59 am
New brakes from metalgear (eBay) Went with stainless steel rotors as the rusty look wasn't working for me! Also got a set of sintered pads so now stopping in the rain won't be such a hit n miss affair. The quality is very good. The discs are nice and fat and heavy and not warped, which is always a good thing :D
Also replaced the rear sprocket with 41 tooth from 40 tooth while wheel was off. This was meant to be done 8000kms ago when I did front sprocket and chain, but they sent the wrong sprocket. The rear wasn't that bad anyway.
Finally got the lower legs of the front brake lines in braided hose. I had bought a set from a 750 but the lower legs are longer than the 906 as it doesn't have a radiator to get in the way. Got some shorter ones made from the next suburb and hooked them up.
Made a garage stand from some timber I had lying around so I could get the front wheel off the ground. It's a couple of mm's lower in height than the underside of the frame when on rear paddock stand. When I lower the paddock stand the bike pivots on the stand and the front comes up. Works mint and cost nothing except for a few screws :thumbup: it's all screwed together and is pretty solid.
Lane
