ducatipaso.org • View topic - 300 to 320mm adapters?
It is currently Wed Oct 01, 2025 4:24 am
 Post subject: 300 to 320mm adapters?
PostPosted: Tue Sep 24, 2013 8:44 pm
Someone selling any adapters f using 320mm discs on the 907?
 Post subject: Re: 300 to 320mm adapters?
PostPosted: Wed Sep 25, 2013 7:09 pm
Don't think I've ever seen those.
PostPosted: Fri Sep 27, 2013 11:23 pm
nope already checked...
I ended having a set custom made by DISCACCIATI - Italy (full floating cast iron).
PostPosted: Fri Sep 27, 2013 11:54 pm
The other way is to get some 1993 907 fork legs that came with the 320 mm rotors. Did the 1989(1990?) 851 have 320 rotors? They had M1R forks, and 17" wheels for one year.
PostPosted: Sun Sep 29, 2013 11:16 am
PostPosted: Mon Oct 21, 2013 8:59 pm
but the total lenght of the 851/M1R is shorter as in the 907.
Bertus
PostPosted: Tue Oct 22, 2013 5:48 am
Yes, the 851 forks are shorter, and shorter travel. But if you get just the lower fork legs, they will fit on your existing forks.
Phil
