ducatipaso.org • View topic - lost key
It is currently Fri Jun 19, 2026 5:30 am
Post new topic Reply to topic  [ 54 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: lost key
PostPosted: Sat Dec 18, 2004 5:22 am
PostPosted: Sat Dec 18, 2004 6:42 pm
PostPosted: Mon Dec 20, 2004 1:41 pm
PostPosted: Mon Dec 20, 2004 7:19 pm
PostPosted: Thu Jan 12, 2006 9:05 pm
Hello all, just thought i would comment on this topic after sourcing new blanks for an existing key (the rounded ignition type and the seat lock). I had great feedback and help from a company in Australia , who identified the key as their key blank number #253
well here's a copy of my invoice for 2 ignition blanks and 2 seat lock key blanks.
2 of #253 GT5BP @ 4.95
2 of #325 MER1@ 3.50
Shipping 2.95
TOTAL US$19.85
Hope this helps someone...
PostPosted: Thu Jan 12, 2006 11:27 pm
Have also dealt with Keys for Classics, very good people. Early '91 907 used left over 906 tumblers, which used very slightly different blank, when told wouldn't work, he immediatey sent the right ones at no charge. Also believe if you can send him the code numbers[on back?] he will cut for small fee. Believe he is running pair of key blanks on Ebay now.[$6.95 plus shipping?]
PostPosted: Fri Jan 13, 2006 2:21 pm
Further on Keys 4 Classics, their blank code for:
906/early 907 SILKA ZD14RP
Later 907 SILKA ZD16RP
My early 907[00920] took 906 blank.
PostPosted: Fri Jan 13, 2006 2:30 pm
Does anyone know where the lock number is on a petrol tank cap???... i have one and provided all the numbers present on the bottom of the cap to the keys4classics guys and they said none of them matched anything they had on record.
So, anyone got any ideas?
PostPosted: Fri Jan 13, 2006 6:57 pm
If you go to Their Ebay listing for key cutting, they list many places where you may or may not find the code. including as last resort removing the tumbler.
PostPosted: Fri Jan 13, 2006 11:25 pm
I'm not so sure the tank needs a key cut to the same specs as the ignition? It wouldn't surprise me if any Paso key opened any Paso tank... but I'm just guessing.
If that is the case, there'd be no reason to have a code on the tank lock.
-Craig
PostPosted: Sat Jan 14, 2006 2:33 pm
As with most ducati's getting one key to open all locks is not something they did... the ignition key is about 3x larger than the hole for the tank cap keyhole.
However i am not sure that the 750 paso ever had a locking tank cap originally, but it is the same size as the 906 and 907ie so it could very probably be one of these.
As for serial numbers none of those on the cap matched anything, and getting the lock out of the cap looked to be extremely hard. so I will use the standard cap that i have until something miraculous hapens to provide an answer.
thanks anyway guys
PostPosted: Sat Jan 14, 2006 2:48 pm
Sorry, hadn't realized this thread had morphed into tank key. All Keys 4 Classics info on key codes is for ignition. BTW my 907 came with non lockable tank cap.
PostPosted: Sun Jan 15, 2006 10:38 pm
My '89 906 does not have a locking fuel cap. The keys for ignition & to lock the seat are different also.
Redpaso
PostPosted: Mon Jan 16, 2006 4:20 am
-Craig
PostPosted: Mon Jan 16, 2006 2:26 pm
