ducatipaso.org • View topic - wiring manual fan switch
It is currently Wed Mar 04, 2026 9:23 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: wiring manual fan switch
PostPosted: Sat Oct 12, 2013 8:11 am
PostPosted: Sat Oct 12, 2013 9:57 am
Hey Warwick, I've just done the same on mine.
All you have to do is hook in to the wires that come out of the bottom of the thermo switch.
Lane
89 Dark Blue 906 Paso
PostPosted: Sat Oct 12, 2013 3:30 pm
PostPosted: Sat Oct 12, 2013 3:41 pm
PostPosted: Sat Oct 12, 2013 4:08 pm
Warwick's drawing shows independent voltage to both the switch and his switch from the battery, not the same thing. if he turns on his switch and the fan switch closes his drawing will give 2 12v sources to the fan
PostPosted: Sat Oct 12, 2013 4:45 pm
I take his drawing as a schematic drawing, which it obviously is. Where you take the 12V from which you manually switch to the fan doesn´t matter. If you run one wire from a consumer load to a battery or two doesn`t make a difference. It`s the same 12V getting there. I can`t believe we`re discussing this.
PostPosted: Sat Oct 12, 2013 10:01 pm
Not so long ago someone posted a pic of a Paso on fire , and there have been others in the past , and here I was wondering if there was some sort of Bemuda triangle thing goin' on here ... Paso's burstin into flames all over the place , but I see a pattern forming here and Im predicting that the next paso to burst into flames will be in Brisbane , Australia :P :lol: :lol:
PostPosted: Sat Oct 12, 2013 10:41 pm
PostPosted: Sun Oct 13, 2013 8:23 am
so you`re saying that this will work and this not ? :wacko:
I don`t know about your toaster but mine runs on AC and hence is a total different thing.
Try to to connect a 12V lamp to a battery and then add a second + wire w/ or w/o a switch in it, then tell us if it lights brighter, blows up and doesn`t light...
PostPosted: Sun Oct 13, 2013 9:51 am
So at the moment I have the second picture setup, via a spare relay outlet. I can change it to pic one if needed. I'll keep watching the debate.
I'm slowly getting the hang of this electrical stuff. No worries about any fires around here :thumbup:
PostPosted: Sun Oct 13, 2013 11:58 am
G as your drawing is both will work, not the best solution but it will work :banghead:
PostPosted: Wed Oct 16, 2013 1:08 pm
ffaarrkk!...this is interesting, I didn't think there could be any new theories and variations to a simple 12v circuit... :thumbup:
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Wed Oct 16, 2013 8:02 pm
I utilised a 12v room thermostat kit, had to change a number of resistors to alter the 5-30c thermostat into a 55-90c device. Purchased at a Maplin store, why it even exists I don't know but I had a use for it. Coupled with a 3 way switch (Off / On / Auto) it is a handy little black box with an LED to indicate fan operation and a dial to fine tune fan temp switching. Probably posted this before but I know what my memory is like.
PostPosted: Wed Oct 16, 2013 10:30 pm
K.I.S.S. two wires two scotchlocks a switch go for a ride
 Post subject: Pay attention, our leader speaks!
PostPosted: Fri Oct 18, 2013 4:46 pm
