ducatipaso.org • View topic - not all BATTERIES are the same !!!
It is currently Tue Oct 27, 2026 10:17 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: not all BATTERIES are the same !!!
PostPosted: Mon Nov 01, 2010 3:55 pm
Deka here too. One will also go in my other bike some day.
My first experience with Deka, though it was not an AGM, was a plow battery that gave me eight years of strong service. It was based on that, that I chose the brand for the bike. I found mine at a Yamaha dealer.
PostPosted: Mon Nov 01, 2010 4:23 pm
PostPosted: Mon Nov 01, 2010 4:32 pm
Seems, that still same problems with batteries as 20 years ago: If same brand, one of they battery is good and another samekind is crap... I think my battery have something broken inside it, as 2 driving seasons is too short for Yuasa. Anyway no warranty anymore, so have to buy something new next spring. :(
PostPosted: Mon Nov 01, 2010 10:03 pm
I have teh Deka's. Sorry for not being complete in my answer.
I get them at the local autoparts store. They have them on the shelf. Just call around. The shop I use is a Carquest.
PostPosted: Tue Nov 02, 2010 10:26 am
PostPosted: Tue Nov 02, 2010 11:14 am
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Thu Jul 18, 2013 1:39 pm
...just to update this post, two days ago I went to start the 907, but the DEKA has finally died :,( ...not bad though, over 6yrs of good service and they don't mind being neglected...hopefully the next will be just as good :beer:
Cheers Claude.
PostPosted: Thu Jul 18, 2013 10:45 pm
The only issue with a Deka is if the bike is going to sit for an extended period you need to disable the clock like a lead acid battery if the voltage drops below 8 volts you have a 50/50 chance to bring it back...o% if it freezes
Lithium gets a big thumbs down on the Paso's you need very tight voltage control so unless you have upgraded your stator and are using a Mosffet regulator don't bother
PostPosted: Fri Jul 19, 2013 9:25 am
I was actually thinking about a lithium battery for the 851, the advantages are obvious, light, small and powerful...but is it going to last?
http://stores.sportbiketrackgear.com/De ... k?no=26638
Cheers Claude.
PostPosted: Fri Jul 19, 2013 9:35 am
model: other
year: 1999
Higgy
Tell us more about the Litnium batteries and older Ducati charging systems. My experience of Lithium batteries is that you need to think of them as 13Volt batteries.
I had to remove the electric fuel pump from a bike with the 300Watt alternator in order to adequately charge a lithium battery (Shorai). No issues now.
Any tips?
2013 M1100Evo Street
1999 M750 "Scrambler"
2004 GSXR750 Track
PostPosted: Tue Dec 03, 2013 6:37 pm
Recently discovered AntiGravity batteries, looks to be a winner
3 year warranty, they even offer a 1 year racing warranty
PostPosted: Tue Dec 03, 2013 6:52 pm
I think I am going to be putting an Antigravity in my Abarth.
PostPosted: Tue Dec 03, 2013 11:53 pm
antigravity makes a 600cca motorcycle battery with a 3 year warranty, unheard of, they will even give you a 1 year warranty if you are racing. even if you manage to muck it up all it does is outgas and then you can just throw it in the trash :thumbup:
the smallest battery they make( 6x1x3 @ 14 oz) is capable of spinning a Ducati 1100 motard 9 times and then has enough left to start your truck lets see a 425cca jump box do that :thumbup:
PostPosted: Sun Dec 08, 2013 5:50 am
$. 219.99 for 12 cells and 289.99 for 16 cells battery???
:wacko: :wacko: :wacko: :wacko: :wacko: :wacko: :wacko:
They will be great but they cost about the double of the Odyssey I fitted on my 907s.
I don't know...
PostPosted: Sun Dec 08, 2013 12:29 pm
