ducatipaso.org • View topic - Oil leak
It is currently Mon Jun 15, 2026 5:05 pm
 Post subject: Oil leak
PostPosted: Sun Dec 22, 2013 6:23 pm
Anyone know what that small screw is for?
Looks like there's oil leaking from there.
The prev. owner had some rubbery epoxy over it which came loose.
paso leak.jpg [128.13 KiB]
Downloaded 226 times
 Post subject: Re: Oil leak
PostPosted: Sun Dec 22, 2013 11:15 pm
I've got the same issue.. Also like to know what they do.
PostPosted: Sun Dec 22, 2013 11:21 pm
PostPosted: Sun Dec 22, 2013 11:23 pm
Yes, it dribbles.
PostPosted: Sun Dec 22, 2013 11:26 pm
PostPosted: Sun Dec 22, 2013 11:32 pm
PostPosted: Mon Dec 23, 2013 3:54 am
I always assumed it was the oil line feeding the head and cams. I assumed it was a cross drilled hole, and that was simply a plug. I have a spare head on the bench. I'll dare to take the screw out and see what's inside. There is some Loctite that seals and holds, but I don't know the part number off the top of my head.
PostPosted: Mon Dec 23, 2013 9:52 am
Yes, a sealed oil gallery. I was advised not to try and remove them. Too soft. Sealed mine with rtv after a very thorough cleaning and it hasn't leaked.
PostPosted: Mon Dec 23, 2013 10:09 am
As stated above it's a blanking plug for an oilway drilling. They are on all the 2V engines and nearly all of them leak sooner or later. Use a thread sealant to keep the oil in.
PostPosted: Mon Dec 23, 2013 11:45 am
Users browsing this forum: No registered users and 39 guests
