ducatipaso.org • View topic - Speedbleeder
It is currently Wed Oct 28, 2026 1:51 am
 Post subject: Speedbleeder
PostPosted: Thu Jan 09, 2014 4:16 am
Hi.
While flicking through another Forum, I found a link to a crowd called Speedbleeder, Web address:
http://www.speedbleeder.com/
After spending an eternity getting the brakes bled after replacing the seals last year, these bleed valves look the goods. They also do a bleed valve for the clutch, which must be a good thing too. Has anyone found these bleed valves before and fitted them? They seem a pretty simple design and comparable in price to normal valves, it makes you wonder a bit?
Cheers.
Nick.
 Post subject: Re: Speedbleeder
PostPosted: Thu Jan 09, 2014 5:58 am
They sure look nifty , but you'd have a job convincing me that they will help bleeding "difficult " brakes or clutches . That ball valve only negates the opening and shutting of the bleed nipple as you bleed , I guess it would free up one hand to tear your hair out while its still not bleeding easily :lol: . A nice wee speck of bling all the same :)
PostPosted: Thu Jan 09, 2014 7:15 am
PostPosted: Thu Jan 09, 2014 9:26 pm
Well Nick , you know what they say ... " Moss doesn't grow on a busy stone " :lol: , and anyhow I have to pay to get mine cut off ..... gotta be a good thing :)
PostPosted: Thu Jan 09, 2014 9:49 pm
Hmm, cheap enough to try.
PostPosted: Fri Jan 10, 2014 12:38 am
No front brake bleed nipples for 907ie shown ??? :banghead:
PostPosted: Fri Jan 10, 2014 9:02 am
yours are either M10x1 or M8x1.25
PostPosted: Fri Jan 10, 2014 10:57 am
Pretty sure the Goldline brakes are M10*1. Same as the back brake.
P750 are further down the list too.
Waiting for an Email from them. Will give them a crack and see how they go.
Cheers.
Nick.
PostPosted: Fri Jan 10, 2014 6:47 pm
PostPosted: Fri Jan 10, 2014 10:50 pm
I ordered some last night. I'll put them on the Sport and the ST, and let you know how they do.
Phil
PostPosted: Sat Jan 11, 2014 12:13 am
keep them covered and clean
PostPosted: Sat Jan 11, 2014 12:20 am
purchased extra boots too.
PostPosted: Sat Jan 11, 2014 8:52 pm
