ducatipaso.org • View topic - New Project 907 evo
It is currently Fri Feb 13, 2026 1:58 am
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: New Project 907 evo
PostPosted: Sun Oct 20, 2013 10:55 am
Keep that wonderful F4 as is...
Don't listen to Mr. G!!!!
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Fri Jan 10, 2014 10:48 am
Spend some time at my friends Bikeshop to work on the Project. I have enough overhours to spend some time home
Bought some time ago the yellow fairing, Tank, all Yellow.
Got all the cables and electric connections done. The Fuse holder is at the moment hanging down, need a good place
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Fri Jan 10, 2014 10:53 am
And the next Project is waiting
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Fri Jan 10, 2014 12:56 pm
That's looking good Bock, that bike will fly. Suggest you change the oil in multistrada legs, I used 600mm of sae7.5 per leg as per manual. That reduced the travel significantly, before I did that I had clearance issues with tyre/radiator. I raised the rad 20mm also. I have raised my legs in the yokes by 15mm now.
PostPosted: Mon Jan 13, 2014 7:37 pm
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Tue Jan 14, 2014 11:38 am
Your rear arm looks about 50mm shorter looking at footrest/tyre position.
Probably be a hairy ride with 4v power. :shock:
PostPosted: Tue Jan 14, 2014 10:44 pm
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Wed Jan 15, 2014 10:54 am
From the swingarm bolt to the center of the wheel is it 520mm to 540mm
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Wed Jan 15, 2014 5:48 pm
907 arm is about 585mm from ctr of pivot to ctr of adjuster slot.
PostPosted: Thu Jan 16, 2014 4:52 pm
Change the Belt's today, fill the Tank. Push the button - running
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Fri Jan 17, 2014 6:07 am
PostPosted: Fri Jan 17, 2014 11:37 am
The way Rudiger is cracking on that will be soon :thumbup: .
PostPosted: Mon Jan 20, 2014 7:16 pm
I took the Original Cockpit from the S4R. Ididnt want to try to convert it into the Paso cockpit. Too much Electronik and too many wires
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Mon Jan 20, 2014 9:01 pm
What yokes have you used Rudiger?
Keith.
PostPosted: Mon Jan 20, 2014 9:11 pm
I use some connection points from the Cockpit holder and use a aluminum plate to block the view and hold the cockpit
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
