ducatipaso.org • View topic - lockable gas cap in the Netherlands
It is currently Thu Apr 30, 2026 2:52 am
 Post subject: lockable gas cap in the Netherlands
PostPosted: Sun Oct 20, 2013 8:40 am
http://www.marktplaats.nl/a/motoren/ond ... ousPage=lr
it does not fit on the 907ie as the hole diameter is different.
 Post subject: Re: lockable gas cap in the Netherlands
PostPosted: Sun Oct 20, 2013 7:56 pm
PostPosted: Mon Oct 21, 2013 7:40 am
really, there are two different ones on the 907ie ?
750/906
outer diameter flange 120 mm
hole circle flange 102 mm
gascap 76mm
907ie
hole circle flange 110 mm
gascap ?mm
PostPosted: Fri Jan 17, 2014 6:30 pm
PostPosted: Sat Jan 18, 2014 7:44 am
