ducatipaso.org • View topic - 907ie ecu markings
It is currently Thu Oct 29, 2026 5:07 pm
 Post subject: 907ie ecu markings
PostPosted: Fri Jan 10, 2014 9:25 pm
Hi Guys,
I picked up a NOS 907 p7 ecu the other day and noticed last night that it has a "CH" stamped on both sides so was wondering if it was designated for the swiss market. It doesn't have a chip in it so are all the p7's the same except for different chips for different markets? Thanks Arch. :beer:
 Post subject: Re: 907ie ecu markings
PostPosted: Sat Jan 11, 2014 12:12 am
all p7's are the same,907,851, Fiat, Maserati et al. The chip does the tuning and mapping there are different versions and levels but any one should work with the proper chip
PostPosted: Sat Jan 11, 2014 8:34 am
I read somewhere that the 91 and 92 P7's varied with the 91 being a bit slower? Might be load of bollox tho.
I have both and they have different numbers, I run a Baines chip in my bike and it seems to run smoother with the older ECU. I put this down to the chip being written for the older ECU.
PostPosted: Sun Jan 12, 2014 2:09 am
P7s for bikes are the same, jusr chip varies.
Car ECU's don't work on bikes due to sensor variations.
PostPosted: Tue Jan 14, 2014 11:24 am
That puts my theory out then............. all an illusion in my mind.
PostPosted: Sat Jan 25, 2014 10:46 am
PostPosted: Mon Jan 27, 2014 1:50 pm
My very knowledgeable friend who runs this business http://hexengineering.se (reprogramming all Duc ECU`s etc) told me so.
One of the ignition sensors is different, IIRC it was a Hall vs inductive thingy.
I have yet to see someone ACTUALLY put a car P8 in a bike..... ;)
Bike P8 are the same, chip varies.
I have a Laverda P8 in mine now, w offset cyl mapping which make a small but noticeable difference.
PostPosted: Mon Jan 27, 2014 2:34 pm
in terms of ECU circuits the difference between an inductive pickup and a Hall Effect Sensor would be minor.
PostPosted: Mon Jan 27, 2014 6:22 pm
Yes, but what I`ve seen, they`re also differently wired pinwise.
PostPosted: Mon Jan 27, 2014 11:35 pm
yes exactly my point, but from what I can find all circuits are included in all P7's and only the chip decides which circuits are active. Also every thing I can find on the different levels of P7's was strictly to adjust off idle charecteristics which was an issue with the p7 on bikes only, it was a throttle response thing. Racers could care less
I did run across one instance with a Lamborghini and a Maserati where a daughter card was added to allow for 2 distributors tied to the corresponding injectors in v8,v10 and v12 street and racing engines and good luck finding one of them in the wild
Forgot Fiat had the daughter card to play with as well :beer:
PostPosted: Tue Jan 28, 2014 1:01 am
OK then, buy a car P8 and surprice us!
PostPosted: Tue Jan 28, 2014 1:56 am
don't need a P8. Just got a new P7. Was looking into a MyECU but he blew me off
PostPosted: Thu Jan 30, 2014 7:05 pm
Archie,
Here is what I got.
PostPosted: Sun Feb 02, 2014 11:06 pm
Yeah Byron, that's exactly like the one I got except mine has the ch stamped on both sides so probably had the chip for the swiss market. Arch.
PostPosted: Sat Feb 22, 2014 8:26 am
I know the US bikes used to have stamped on the chip "023 us". That chip grants a leaner work of the engine for pollution reasons (according with the US laws).
Are there some ch chips, too? Differences?
