ducatipaso.org • View topic - Ducati Regulator replacement help needed
It is currently Thu Oct 29, 2026 11:02 pm
 Post subject: Ducati Regulator replacement help needed
PostPosted: Sat Mar 01, 2014 1:16 pm
Hi folks I need to source a new Regulator silly prices this country so far but have seen this one Stateside however the postage seems very expensive ...so is there anyone that side of the pond that might know if it can be sourced and posted cheaper?
http://www.ebay.co.uk/itm/Ducati-907-i- ... 35d256e6c5
Or is there a possibility of one somewhere else in this big old world of ours?
Thank you :thumbup:
 Post subject: Re: Ducati Regulator replacement help needed
PostPosted: Sat Mar 01, 2014 2:07 pm
Stiv, have you tried
That is where I found mine
PostPosted: Sat Mar 01, 2014 3:27 pm
this looks the same. The M900 1995 is listed also in the auction you posted. If it`s the Electrosport ESR510 it`s what you`re looking for. (If it`s not they might be able to get the correct part for the same price). I`d ask.
http://www.ebay.co.uk/itm/Ducati-M900-M ... 1e74438f73
This one incl. shipping is even cheaper but if it comes with that connector it will require a little modification. You`ll have to ask also here ;)
http://www.ebay.de/itm/Laderegler-fur-D ... 19e93fd46f
PostPosted: Sun Mar 02, 2014 12:59 am
I have one of these on my bike. It's been 6 years or more.
http://www.electrosport.com/street-bike ... ifier.html
Also take a look at the following
http://www.mgcycle.com
https://store.bevelheaven.com/index.php
http://www.rmstator.com/en/motorcycle/d ... so-ie/1992
http://www.euromotoelectrics.com/category-s/1265.htm
PostPosted: Sun Mar 02, 2014 10:19 am
PostPosted: Sun Mar 02, 2014 12:38 pm
Thank you folks. Derek thank you I have PM'd you.
PostPosted: Sun Mar 02, 2014 2:29 pm
If you aren't bothered about the warning light there are a great many regulators that can be used and if you want to retain the warning light you can fit one of these, like I did.
Use a positive earth version with the pink wire connected to ground the charge warning light, the black to earth and the red to the switched feed from the ignition.
