ducatipaso.org • View topic - Rubber cap hor. cylinder - 906/907
It is currently Sat May 02, 2026 9:17 am
 Post subject: Rubber cap hor. cylinder - 906/907
PostPosted: Tue Mar 25, 2014 3:27 pm
Hi.
Can anyone help med with the rubber cover for the belts. It is the one for the horizontal cylinder.
Ducati partnumber : 23510061A
http://www.stein-dinse.biz/Komplettange ... :8598.html
 Post subject: Re: Rubber cap hor. cylinder - 906/907
PostPosted: Tue Mar 25, 2014 9:54 pm
I had to rebuild mine as it was cracked around where the screws go in . I would have a look at the later model 2 valve motors , I aint sure ( G probly knows :) ) but I would think that the later SS motors would have the same piece on them and it may be available under a different part #
http://www.oiltalavante.com/DUCATI-23510061A/en . I just had a quick look and this lot have one for 15 euro , I have no idea where they are
H
PostPosted: Wed Mar 26, 2014 7:19 am
Hi.
I have a order pending at them, but they are not able to get it. Have also tried Stein Dinze but no luck.
I will try to look at the other models to see if they could fit - thanks.
PostPosted: Wed Mar 26, 2014 10:56 am
it's the same part on all the 904/944 engines - SS, Monster, ST2
PostPosted: Wed Mar 26, 2014 11:21 am
actually it`s not http://www.stein-dinse.biz/Komplettange ... tyPhoto/0/ but if that tongue is cut off it probably will be.
PostPosted: Wed Mar 26, 2014 12:48 pm
I have ordered this and will try a small modification. I will report back if it works...
PostPosted: Wed Mar 26, 2014 7:50 pm
