ducatipaso.org • View topic - Rear brake disc bolts
It is currently Sun Apr 26, 2026 10:02 am
 Post subject: Rear brake disc bolts
PostPosted: Mon Apr 07, 2014 3:02 pm
I am refurbishing a set of wheels which is missing the disc bolts at the REAR
I tried ordering them through the Ducati dealer but I am told the code has been discontinued and that there is no replacement; most of the times part numbers are are replaced by other s used in different models, apparently this would be one of the odd cases where there is no replacement.
I am thinking that maybe the ST2 ones are the same (maybe longer?), does anyone know?
 Post subject: Re: Rear brake disc bolts
PostPosted: Mon Apr 07, 2014 6:30 pm
The disc retaining bolts on most Ducatis are the same, usually M8 x 20 with a low profile hex socket head.
PostPosted: Mon Apr 07, 2014 8:00 pm
Which would be available at any Fastener supplier, probably a lot cheaper than any Ducati supplier! :D
PostPosted: Tue Apr 08, 2014 11:03 am
Actually you would be very much surprised... the ST2 rear brake disc bolts are priced around 0.75GBP (1.25$) from the local ducati dealer.
Sometimes it is worth giving them a call to find out, certain parts are veryy expensive, others are surprinsingly cheap.
