It is currently Wed Oct 28, 2026 12:43 am
 Post subject: New Owner
PostPosted: Wed Apr 09, 2014 4:45 pm
Hello
I am new in this forum
Drive past few decades Ducatis and I have now bought a 907ie.
The motorcycle comes from a collection unfortunately some things had not been seen.
Service Jam, no timing belt change, damaged rear swing arm caused by incorrect installation of the spacer sleeve. :lol:
On both side panels are missing the retaining plug to the tank.
For this, a question for you
Is there a repair solution for the side panels.?
regards
Uwe
 Post subject: Re: New Owner
PostPosted: Wed Apr 09, 2014 7:57 pm
Hi Uwe , welcome to the mad house . I have seen side panels on e bay , which probly would have to include a paint job . If you have the broken off bits a good polyester glue should stick em back on . :)
PostPosted: Thu Apr 10, 2014 12:41 am
Welcome Uwe,
whitch part of Germany are you living?
Regards
Rüdiger
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
PostPosted: Thu Apr 10, 2014 5:04 am
Hi Rüdiger
Hessen northeast,near from Fulda.
Regards
Uwe
PostPosted: Thu Apr 10, 2014 5:09 am
Hi Mr.Tool
There are no plug and gums as a model on motorcycle
Regards
Uwe
PostPosted: Thu Apr 10, 2014 6:11 am
" and today's cryptic X word clue is ................. :)
Then I would investigate fitting some well nuts to the tank and drilling 6mm holes where pins used to be and use some 6mm fairing screws to attach side panel , gee ! if you did it right it would probly look "factory "
Hamish
PostPosted: Sat Apr 12, 2014 8:26 am
Last 907s (like mine black one) don't have the big plugs on the rear fairings and the gum on the tank.
They only have some little cylindrical plugs and no gum.
She came so by factory. I bought mine stock and with very little mileage.
Don't worry.
PostPosted: Sun Apr 13, 2014 8:54 am
Hello
Thanks for the reply
Without fixing the side cover scrubs the tank
The variant where the two plugs sit in rubber would be useful
So I thought
Have glued hard rubber provisionally small spacer.
Yesterday was the first test drive with Bridgestone S20 120/170
Runs very well
Unfortunately, caused by the previous owner opened the air filter box when accelerating very strong noise.
The little things are no problem.
Regards
Uwe
PostPosted: Tue Apr 15, 2014 6:49 pm
He may removed the short, round Air Intakes. Get Noisy but mine runs better without.
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
