ducatipaso.org • View topic - 1989 900 Supersport running on one cylinder
It is currently Sat Feb 28, 2026 8:01 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: 1989 900 Supersport running on one cylinder
PostPosted: Fri Apr 18, 2014 7:35 pm
PostPosted: Sun Apr 20, 2014 2:48 am
If you ran the tank almost empty, then you may have picked up some water out of the tank and put it into the carb. Can you drain the carb? I don't have a Weber to see if there is drain plug. Follow with a bit of Sea Foam and go for a hard run.
PostPosted: Sun Apr 20, 2014 9:26 am
PostPosted: Sun Apr 20, 2014 10:02 pm
Yeah but , as the level gets real low the remaining fuel starts to really slosh around stirring up all the shit ( inc water ) , mixing it all up and it goes out with the fuel :)
PostPosted: Sun Apr 20, 2014 10:45 pm
model: other
Can you clarify that a bit more, as I'm reading it, if you leave the choke on it continues to run on 2 cylinders? and only cuts to one when it shut off.
Again I say fuel starvation, :D and what all the boys are saying in various ways, is clean out the carb, jets needles, float bowl etc. before paying someone what may unnecessarily do what is a fairly I think on a webber simple bit of maintenance, fella's is it?
Peter
PostPosted: Mon Apr 21, 2014 12:26 am
Yup , probly got a lump of shit in one idle jet . :)
PostPosted: Mon Apr 21, 2014 2:22 am
Yeah, Pull it apart, clean things up, probably needs a new fuel filter anyway. I'll go with the clogged idle jet. Runs really bad with that clogged.
PostPosted: Mon Apr 21, 2014 9:06 am
if it runs on both cylinders at higher rpm it`s not a clogged jet. Usually that`s due to a voltage drop at the coils. As soon as you raise rpm and voltage increases the non firing coil starts working and the second cylinder kicks in. My bet would be on that.
I`d rule out the simple things first before taking the carb apart.
PostPosted: Sat Apr 26, 2014 8:35 pm
Thanks for all the advice guys. The bike went into the shop yesterday as I dont have the space at the moment to work on it myself. Its all sorted now and the diagnosis was........drum roll..............water in one of the carbs. The tank was drained, but no water was found in there and the carbs were cleaned out fully aswell and everything is hunky dory.
PostPosted: Sat Apr 26, 2014 8:54 pm
PostPosted: Sat Apr 26, 2014 9:00 pm
They did specifically say it had the original Weber
PostPosted: Sat May 10, 2014 10:00 am
Well guys, turns out everything wasn't as hunky dory as first thought. I picked the bike up last week and as soon as the mechanic bought the bike out it was clear that it was still running on one. I was assured it was on two and that it just needed a good run to bed in and the 25 miles back home would sort it. Despite having paid out to have the carbs drained, cleaned and balanced. At 4000rpm and a steady throttle it was misfiring and coughing and splutteting like a pig, but at higher revs and a good crack on the the throttle she flew. So I got home, removed the rear plug cap and she cut out. Statted her up, removed the front cap and she still ran. Rang the shop up and was told maybe we shouldve taken it out for a test ride! This from a Ducati main dealer!! So, my finger is pointing squarely at the coil, but can anyone tell me please what model is compatible with my old girl as trying to find one is proving to be a nightmare. Thanks again guys.
PostPosted: Sat May 10, 2014 10:06 am
I did wonder about that repair as the Weber has only one float chamber and water in it wouldn`t explain why the bike runs only on one cylinder.
However, swap the coils to see if one is really defective and do finally measure the voltage at the coils !
PostPosted: Sat May 10, 2014 10:23 am
Thanks G. I'm going to nip out to the shed once the rain eases up (good old English weather lol) and take a look. Unfortunately I dont have anything to measure the voltage but I'll try swapping the coils over.
PostPosted: Sat May 10, 2014 10:41 am
Lane
89 Dark Blue 906 Paso
