ducatipaso.org • View topic - anyone having problem with gear box???
It is currently Thu Nov 13, 2025 7:29 am
 Post subject: anyone having problem with gear box???
PostPosted: Wed Apr 30, 2014 2:39 am
my 907 just start having problem with the 4th gear, lately sometime while driving when i shift from 3 to 4 and 4th gear feel like in neutral it wont move even if i give it some gas, and if i downshift from 5 to 4 and it working fine. is there any1 having the same problem like me????
thank!
 Post subject: Re: anyone having problem with gear box???
PostPosted: Wed Apr 30, 2014 5:40 am
Not me
PostPosted: Wed Apr 30, 2014 8:41 am
There is an adjustment inside the alternator cover that centralises the selector fork. It has a spring which may have broken causing selection problems.
PostPosted: Wed Apr 30, 2014 9:58 am
I had a very similar issue ages ago, I though it was the control fork that needed to be reset / adjusted, then while I was taking it apart i noticed that the gear lever was very dry and would seize in certain positions, so I just lubricated the pin, re-tested and ... hei presto, all problems sorted.
So, summarizing
- check lever smoothness
- set the control fork; for this you might need to take off the oil (if you lean well the bike you might avoid this, but I am not sure..)
PostPosted: Wed Apr 30, 2014 4:28 pm
is it easy to adjust or reset the control fork? just take off the alternator cover?? last year i replaced the starter but never pay attention to the control fork, and gear been working fine until after i replace the starter
PostPosted: Thu May 01, 2014 4:09 am
ok i got the alternator cover off. seen like everything is fine, spring is fine too, i try to look at the work shop manual for control fork adjustment on 907ie they dont have it there. but i found one for 906 work shop manual, so i wonder if both bike work the same way?? another question: if i do wanna take out the control fork to have a clear look and make sure it work fine, i need to remove the flywheel to get access to it???
thanks
PostPosted: Thu May 01, 2014 9:06 am
yes and yes.
The 907ie wsm is a supplement so you need the 906 & 907ie wsm to have a complete 907ie manual.
To remove the gear selecter mechanism the flywheel needs to me removed (F.13 of the 906 wsm).
Inspection of that mechanism is described in the Haynes manual (2.28).
Be sure you know what you`re doing as a lot of bad things can happen if the flywheel nut isn`t mounted & tightened correctly. It also needs an alternator holding tool to undo and tighten that nut btw.
PostPosted: Thu May 01, 2014 6:14 pm
i couldnt find the Haynes manual on the site. can u help me with a link
thanks
PostPosted: Thu May 01, 2014 7:26 pm
viewtopic.php?f=1&t=1551
