ducatipaso.org • View topic - 907ie swingarm
It is currently Thu Nov 13, 2025 8:14 pm
 Post subject: 907ie swingarm
PostPosted: Sun May 25, 2014 8:27 pm
I need a new swingarm for a 1993 907ie.
I'd be interested in hearing from anyone who:
*Has one to sell
*knows of someone who has one to sell
*knows where I can get one
*knows what other models if any use the same swingarm.
Sheldon
 Post subject: Re: 907ie swingarm
PostPosted: Tue May 27, 2014 3:54 pm
I`ve only seen one for sale and that`s in really bad condition needing some welding due to the so commonly reverse installed wheel spacer.
No other model uses that swingarm.
PostPosted: Wed May 28, 2014 1:48 am
What has happened Sheldon ? . Did you get the swing arm out ok ?
Hamish
PostPosted: Wed May 28, 2014 6:58 am
There is one on eBay: 310662013477
Kindest regards,
Kevin
Kindest regards,
Kevin
907ie 1992
ST4s 2002
750SSie 2002
Cagiva Gran Canyon 1999
Norton Commando 750 1971
PostPosted: Wed May 28, 2014 7:47 am
I was referring to that one. I guess Kevin`s swingarm can`t be worse than that.
PostPosted: Wed May 28, 2014 8:03 am
Yes Paso750, you're right; my swing arm is in excellent condition, and it's on a 1992 7.500km bike that I got only last week...
I thought I would let Sheldon make up his mind about whether he was interested in the eBay item.
It may well be that his own swinging arm is beyond repair, and this one can fairly easily be sorted. I'd be tempted to try a 'Lumiweld' or 'Alumiweld' repair, which might avoid any possibility of distortion through welding by using only a butane torch.
Kindest regards,
Kevin
Kindest regards,
Kevin
907ie 1992
ST4s 2002
750SSie 2002
PostPosted: Wed May 28, 2014 9:03 am
PostPosted: Thu May 29, 2014 3:35 am
You may want to try http://www.ducpower.com
PostPosted: Thu May 29, 2014 9:58 am
Not so sure I would use lumiweld type products on a swing arm or any other structurally stressed part.
PostPosted: Thu May 29, 2014 10:35 am
Why not?
Lumiweld claims to have superior tensile strength to aluminium, and whilst the swinging arm is made of an alloy, and will be stronger in any case, neither of the worn areas are subject to much tension, compression or deformation.
With regard to the swinging arm available on eBay, the damage is not in critical areas subject to stress or strain - they are due to chain wear and an incorrectly oriented spacer. Neither area is critical for structural integrity in my opinion, and is evidenced by lack of fractures or failure in the areas in question.
If I wasn't bothered about looks I'd leave the chain worn area, and on the area by the wheel spindle slot... just dress it with a file and maybe use JBWeld to repair the depression.
A scruffy but pragmatic repair perhaps...?
Kindest regards,
Kevin
907ie 1992
ST4s 2002
750SSie 2002
