ducatipaso.org • View topic - new Paso owner
It is currently Thu Jun 18, 2026 1:27 pm
Post new topic Reply to topic  [ 141 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10  Next
 Post subject: Re: new Paso owner
PostPosted: Thu Jun 05, 2014 5:03 am
So, BirdDuck, where exactly in the grand ol USA do you live that you can't find Ducati parts?
After e-bay and Craigslist, there's ducati breakers like Nick Anglada https://www.facebook.com/UsedDucatiParts and GuzziTech.
Everything is possible to find on the internet, of course patience is required, and a paypal account. Some parts have taken me several years to find, like my 300mm cast iron full floating Brembo rotors, new in a box.
But if you are interested in a set of stock Mikunis and a stage 1 kit, drop me a line. they are in the garage some where, and I'm on the Dellorto wagon, so I won't be using them.
PostPosted: Thu Jun 05, 2014 1:17 pm
its mostly keeping cost down, didn't intend on running into issues of ham handed previous owner :(i am in Utah. how much are you thinking? and would i need manifolds as well?
PostPosted: Thu Jun 05, 2014 1:34 pm
inlet manifolds + rubber boots + 2 throttle cables & accelerator throttle + SS choke cable + air filters + the usual small bits
PostPosted: Thu Jun 05, 2014 2:29 pm
has anyone used the round slide mikuni carbs? there is tones of those around for cheap. i believe they are mostly off two stroke applications, i thought i have seen them on some other models of ducs maybe the bevel engines?
PostPosted: Thu Jun 05, 2014 2:46 pm
:cool:
Phil has made you a good offer. Why don't you do as he suggested, and drop him a line?
PostPosted: Thu Jun 05, 2014 3:26 pm
i did.. :)
PostPosted: Thu Jun 05, 2014 8:38 pm
He will be getting the boots, manifolds, stock carbs, Stage 1 Dynojet kit, and a throttle if I can find it. After owning it for 5 years, and taking up shelf space, I'm glad to make some room
I'll be making some more room in the coming weeks as I might be moving shortly, and need to start cleaning up.
PostPosted: Thu Jun 05, 2014 9:44 pm
:cool:
Well done, Phil!
PostPosted: Fri Jun 06, 2014 5:12 am
Found the problem.. 7v to the coils.... Fixed.. 11.7v now :) thanks for the nudge on checking the coils.. still want carburetors though :D
PostPosted: Fri Jun 06, 2014 1:31 pm
WOW talk about a different machine now 0_o!
PostPosted: Fri Jun 06, 2014 3:36 pm
Even better with some Dyna Coils and a relay inline.
PostPosted: Fri Jun 06, 2014 4:48 pm
wired it up last night. direct power from the batt to a relay with on with key on. every connection is soldered and shrink wrapped, 8ga wire feeding the coils juice :D.. the electric engineer for ducati must have been on acid or something with how all the systems are run :S
PostPosted: Fri Jun 06, 2014 4:54 pm
8ga is just a bit over the top :mrgreen:
PostPosted: Fri Jun 06, 2014 5:26 pm
Its not done till its overdone.
PostPosted: Fri Jun 06, 2014 7:32 pm
If you're thinking Mikuni carbs, here is what mine look like: IMG_0752 - CopyB.jpg
