ducatipaso.org • View topic - new Paso owner
It is currently Thu Feb 26, 2026 6:34 pm
Post new topic Reply to topic  [ 141 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
 Post subject: Re: new Paso owner
PostPosted: Fri Jun 06, 2014 8:22 pm
Yeah, them is FCR's.
a great carb. Not the stock carbs from the SS / Monster.
Phil.
PostPosted: Fri Jun 06, 2014 9:47 pm
FCR's are Keihin Them B mikuni flat slides
PostPosted: Fri Jun 06, 2014 10:50 pm
I stand corrected.
another option for carbing the Paso.
Phil
PostPosted: Sat Jun 07, 2014 12:14 am
getting some mikuni's(monster setup) from phil, because he is awesome and likes his garage space :D.. its what i had, i figured to big is better that not big enough..
PostPosted: Fri Jun 13, 2014 7:29 pm
what is a good idle speed for the pantah?
in its currant state, i cant get it to stay running under 1300rpms..
i have carbs coming from phil so not worried about toying with the weber anymore.
but i would like to know what some other are running..
PostPosted: Tue Jun 17, 2014 6:34 pm
mikuni's on and running.. need to locate to rubber grommets that seal the fuel inlet, filters and a throttle cable.. other than that jet kit installed and carbs cleaned and bolted on :) thanks phil !!
Update:
Cables acquired, filters acquired all installed.. just setting up fuel system next, the old setup was not working well with the new carbs..
PostPosted: Wed Jun 18, 2014 12:42 am
Lane
89 Dark Blue 906 Paso
PostPosted: Wed Jun 18, 2014 1:00 am
hmm mine was pushing fuel out of the inlet seals.. i am assuming there just shot..
PostPosted: Wed Jun 18, 2014 9:13 am
Lane, you`re in the P750 forum. ;) Only very few 750s had a Marelli Digiplex ignition. Most had the Kokusan ignition just like the later carbed Supersport and Monster or Cagiva Elefant.
PostPosted: Wed Jun 18, 2014 11:36 am
....whoops sorry.. :smoke:
Lane
PostPosted: Wed Jun 18, 2014 11:38 am
...that's 14 minutes of my life I'll never get back :mad:
Lane
PostPosted: Wed Jun 18, 2014 4:35 pm
going to ditch the fpr and redo my fuel lines tonight.... everything else is ready to go..
and just a heads up for anyone that wants to know a 2002 honda crf450 throttle cable will work almost
perfectly, the only flaw is that the pull barrel adjuster is a tad to small to thread in but large enough
that it doesn't flop around.. 22$ at my local powersports shop, filter are uni's and where 15$ each.
PostPosted: Wed Jun 18, 2014 4:49 pm
Thought I'd chime in on the carb set up, since I swapped my '88 over to a pair of Mikunis last summer (with lots of remote help and a custom-made cable bracket from Gerhard).
I found a connected pair from a mid-90s SS900 on ebay for ridiculously cheap ($60USD) a couple years ago. I fit them with a Dynajet stage 3 kit for the SS, because I installed K&N pod filters (P/N SN-2530) and I already had a pair of Cobra F1 exhaust cans on there (and they're pretty free-breathing). The connected pair simplified the set up in that I could use the throttle tube from a Monster/SS & that bike's stock twin-cable set up, as well as replicate that fueling process:
I ditched the Paso's stock electric fuel pump in favor of the Mikuni vacuum-fed pump from a Monster, and I routed the fueling from tank > filter (canister-type from a Monster, left side of bike) > fuel pump > carbs. I mounted the vacuum pump on the right side of the bike (clutch side) in a V in the frame, and 'power' it from the nearest intake manifold.
I swapped the manifolds for a pair from a SS as well; I wound up with a pair from a 900, which are slightly longer than the pair from a 750, which twist the carbs slightly, but that's a non-issue. Actually, I was happier with that, because I think made more room for the pod air filters.
While I obviously ditched the airbox, I kept the crankcase breather box, which lives right in front of the battery, under a short frame cross-member. That previously fed the Weber's airbox, so I wound up installing a filter instead. That's secured to the frame, towards the front of the bike on the left side.
I also added the triangular 'null air' box from a Monster/SS, which fits nicely into one of the upper V's in the frame (right side) into which the carbs 'breathe'. You'll see the set up in any pre-99 Monster/SS parts explosion. Each carb has an air line (with a one-way valve?) that blows into a grey plastic box.
Besides the K&N items, 2 new throttle cables, air/fuel lines, fuel filter, intake gaiters and necessary clamps - everything was picked up from ebay and shops like ducpower/guzzitech. The air filters I found cheapest on Amazon; the cables, fuel filter & intake gaiters came from Ducati. All told I think I spend under $150USD, and several hours horsing around.
And the bike is transformed. I tried a number of alternatives with the Weber, although admittedly not the solution Jon has detailed :| but I'm extremely satisfied now. The bike has never run this well. Starts like a champ, warms up quickly, idles comfortably around 900-1000 and pulls hard everywhere with no stutters or plateaus.
1988 Paso 750 #753965
1997 Monster 750
PostPosted: Thu Jun 19, 2014 3:20 am
just have to thank phil.. if he was here i would give him a hug..!!!
bike is a new machine, throttle reponse is perfect, acceleration is smooth and there is no hesitation..
install is clean and looks good, fuel system working perfectly and i fixed my leak!
PostPosted: Thu Jun 19, 2014 4:03 am
This is a photo I took just before embarking on my mikuni swap.
