It is currently Wed Oct 28, 2026 11:17 am
 Post subject: instrument panel removal 907ie
PostPosted: Fri Jun 13, 2014 9:11 pm
Hi everyone new to the forum so heres my problem, I have a 907ie from 1992 which hasnt ran for 12 years after a week of cleaning injectors new in tank pipes I managed to get her going well, but i noticed the 3x rubber support dampers that hold the instruments to the frame had fell apart, unluckily for me one had left a blind lug in the panel so I need to remove it to extract the said lug. I have removed the speedo and rev cable and the multi wire clip connectors but there is a wire on the right hand side if looking from standing in front of the bike (rear of instruments) left side of panel when sitting on the bike that i am not sure if this just pulls out or is there a special method of removal, I don't want to force it in case I break something as parts are getting difficult to come by. many thanks for any help with this re Alistair
 Post subject: Re: instrument panel removal 907ie
PostPosted: Fri Jun 13, 2014 9:30 pm
Alistair, that`s the cable to the odometer zeroing knob as the manual calls it.
Don`t remove the cable from the instrument panel. Just remove the flat knurled nut from the zeroing knob and remove the complete instrument panel with the cable.
PostPosted: Fri Jun 13, 2014 9:43 pm
Thanks for the advice on the cable its much appreciated re Alistair
