ducatipaso.org • View topic - Speedo/Tach cables ... same thing?
It is currently Sun Sep 28, 2025 11:28 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Speedo/Tach cables ... same thing?
PostPosted: Tue Jun 17, 2014 9:49 pm
or in the documents section of the main page.
PostPosted: Wed Jun 18, 2014 10:20 am
PostPosted: Wed Jun 18, 2014 3:24 pm
eesh. Well, hopefully, since I'm going through a proxy (MG Cycle) that won't be a problem ...
1988 Paso 750 #753965
1997 Monster 750
PostPosted: Wed Jun 18, 2014 3:40 pm
In all the years I didn`t have any negative experiences with SD and if there was something to clarify I`d do it via telephone not email ;)
PostPosted: Thu Jun 19, 2014 4:10 pm
PostPosted: Sun Jun 22, 2014 9:43 am
I just bought a new speedo cable for my 907 from Mdina Italia in the UK.
They had one in stock but it couldn't be found, so new batch was ordered and they had one to me in less than a fortnight.
I tried first tried, through my very helpful parts guy at Ducati Glasgow, to find a suitable alternative but none of the currently available cables from Ducati are long enough (Monster, SS, ST, 748/916).
PostPosted: Sun Jun 22, 2014 4:30 pm
Just to make things funny (more ironic than ha-ha), now my speedometer has stopped working. So yesterday I went to pull both cables off the bike, and they both appear to be fine. :( Actually, the speedo cable looks a little mangled at one end, but the tach cable is fine. It appears the tachometer itself has quit; I can't get the needle to budge even a little, spinning it by hand. It was a little depressing yesterday morning, on my way to work, to see that the only functioning gauge was the fuel gauge. (The oil temp works ... sort of). And since I like my tach more than I like my speedo, I'm looking for a new gauge cluster ... I do have a line on one. The good news is this one appears to have its mounting studs intact. (Upgrade bonus!) LOL
1997 Monster 750
PostPosted: Sun Jun 22, 2014 6:15 pm
Remove the instrument panel, then remove and check the angle drives at the back. They should be slightly greased.
When they are removed try to spin the instruments directly to see if they are really not reacting.
PostPosted: Sun Jun 22, 2014 9:46 pm
1997 Monster 750
