ducatipaso.org • View topic - new Paso owner
It is currently Tue Oct 27, 2026 2:14 am
Post new topic Reply to topic  [ 141 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10  Next
 Post subject: Re: new Paso owner
PostPosted: Sun Jun 29, 2014 11:29 am
PostPosted: Sun Jun 29, 2014 3:50 pm
http://www.rockymountainatvmc.com/p/142 ... n?term=uni
PostPosted: Tue Jul 08, 2014 1:21 am
whats a good ignition upgrade to use from another ducati? going to search now but curious what luck you gents have had..
PostPosted: Tue Jul 08, 2014 10:09 am
there is none. The Kokusan ignitions of carbed Ducs are all the same. What you can do is go for aftermarket parts like Dyna coils. Aftermarket ignition modules only make real sense with other engine modifications.
PostPosted: Tue Jul 08, 2014 4:19 pm
mostly wondering because my bike has two different modules. and at low rpms the front bank will occasionally miss fire and cause it to backfire through the intake... are the pick ups adjustable or servicable? i looked through the faq page but was unable to find much on the pic ups.
PostPosted: Tue Jul 08, 2014 4:34 pm
two different modules ? Do you have a picture ?
The clearance pick-up to flywheel is adjustable.
The pick-up signal output is 05-06V when cranking and 1,6-1,9V at idle.
Pick-up clearance is 0,9mm +/- 0,15mm. (many places recommend 0,7-0,8mm for street and 1,0-1,5mm for race use)
If there are starting issues with cold engine the gap can be reduced by 0,2-0,3mm. In case there are issues in the high revv range the gab can be increased by 0,2-0,3mm.
Some info should be in the workshop manual, Haynes or others you can find on this forum.
PostPosted: Wed Jul 09, 2014 2:36 am
i can post one tomorrow..
yeah one says ducati performance and the other is just a plain looking balck box.. the duc perf one has an led and fancy red letters
PostPosted: Wed Jul 09, 2014 8:29 am
The Ducati Performance CDI unit (formerly from Pederzini) has a different ignition advance curve.
PostPosted: Thu Jul 10, 2014 2:29 am
I guess that would explain the low rpm stumbling
PostPosted: Thu Jul 10, 2014 8:19 am
the black one is the original Kokusan Denki BB1105
PostPosted: Wed Jul 16, 2014 4:25 pm
new igniter will be here today, see if this fixes all of my woes
 Post subject: still having issues
PostPosted: Thu Jul 17, 2014 4:25 am
So after everything I have done to battle the sputtering at light throttle its still there, new carbs new igniters and endlessly checking wires....
here is the symptoms, light throttle no load situations the engine will stutter. . I have checked almost everything electronic starting to thing its a physical thing. Is it at all possible to the points to be loose or something..??? I tried to find an image of them but have not had much luck. .. another things is when the engine get full temp it backfires through the intake on the front cylinder. Only when hot
 Post subject: Re: still having issues
PostPosted: Thu Jul 17, 2014 8:32 am
Sounds to me it's running too rich and your timing is out...but I ain't no mechanic :huh:
Lane
89 Dark Blue 906 Paso
PostPosted: Thu Jul 17, 2014 10:21 am
Have you Synced the carb(s) with a manometer ?
PostPosted: Thu Jul 17, 2014 12:14 pm
I synced the the throttle plates but I don't own a meter..
