It is currently Wed Oct 28, 2026 3:47 am
| Author |
Post subject: Re: Single Cylinder Paso Posted: Tue Jul 08, 2014 4:27 pm |
| paso grand pooh-bah |
the red wire to the starter is connected to one side of the starter solenoid. All other red wires are connected to the other side. The thinner red/yellow one coming from the starter button switches it.
| Top |
WPT Paso
Post subject: Re: Single Cylinder Paso Posted: Tue Jul 08, 2014 4:34 pm |
Joined: Thu Jun 05, 2014 2:47 pm Posts: 9 Location: USA
That's the way I wired it, something has changed though, as soon as i add power to the solenoid the bike starts, interestingly enough when I pull the power it won't stay running. I am wondering if maybe it is a stuck relay.....and if there is a replacement relay for the Sipea 1440.
Thank You
| Top |
angelix
Post subject: Re: Single Cylinder Paso Posted: Tue Jul 08, 2014 8:21 pm |
Joined: Thu Nov 29, 2007 2:38 am Posts: 338 Location: UK
The relais on that bike are very common (actually most automotive relais are very common) and if you check carefully on the case itself you will see a diagram of how it works; with that in hand you can easyly find a pin-to-pin replacement in probably any good spare parts dealer.
When I say good, I mean ran by somebody capable of matching your relay; Nowadays often the dealers just read the part codes and the PC screens...
if you go to a DUCATI dealer and ask for an old part number , most likely they will have difficulties to even find the fiche of the bike model you are referring to.... then if you dig a little you discover that the same item with different part numbers is used in 127 models , across 4-5 different brands including tractors, lorries and cars.
| Top |
Users browsing this forum: No registered users and 9 guests |
