ducatipaso.org • View topic - Tubeless valve stems
It is currently Tue Oct 27, 2026 10:36 am
 Post subject: Tubeless valve stems
PostPosted: Fri Jul 11, 2014 6:57 pm
Hello all,
I need to replace my rear valve stem as it is broken. Do the Oscam wheels use a special size, or can I use any standard size replacement?
 Post subject: Re: Tubeless valve stems
PostPosted: Sat Jul 12, 2014 4:33 am
many of the standard sizes available might fit :D
PostPosted: Sat Jul 12, 2014 9:58 am
They come in 8.3mm and 11.3mm sizes to fit the hole in the rim. For a Ducati you need the smaller 8.3mm size. Like these -
PostPosted: Sat Jul 12, 2014 6:41 pm
Great news, thank you for helping me out. Those were actually the ones I was wanting to get. :beer: :beer:
PostPosted: Mon Jul 14, 2014 3:27 am
The right angle ones look real good but I found they fouled the front calipers if you have them at 90 deg
PostPosted: Mon Jul 14, 2014 3:58 am
I was told by the tyre shop that the right angled ones didn't fit as they weren't long enough for our rims :mad:
So, for a few dollars, I bought a brass right-angled adaptor valve-extension to screw on when checking tyre pressures. He had some on the counter. I keep it under the seat. Works mint. :thumbup:
Lane
89 Dark Blue 906 Paso
PostPosted: Mon Jul 14, 2014 9:29 am
PostPosted: Mon Jul 14, 2014 12:34 pm
PostPosted: Tue Jul 15, 2014 5:30 am
PostPosted: Wed Aug 06, 2014 2:25 am
I found these to be a perfect match to the original by a company called K&L and sold through The Motorcycle Superstore. They seem to be good quality, too.
http://www.motorcycle-superstore.com/36 ... valve-stem
Users browsing this forum: No registered users and 204 guests
