It is currently Sat Jun 20, 2026 1:47 am
[ 6 posts ] |
| Author |
fasterdammit
Post subject: Torque setting for clutch plate screws? Posted: Fri Jul 11, 2014 4:14 am |
| paso grand pooh-bah |
Joined: Wed Jan 19, 2005 12:00 am Posts: 708 Location: CNY, US
Putting my clutch back together (finally), and I don't see a torque setting for 6 screws that hold the pressure plate against the basket. Do you just snug the plate up to the posts, hand tight?
Thanks!
_________________ Just because you're not dead doesn't necessarily mean you're living, either.
1988 Paso 750 #753965
1997 Monster 750
| Top |
Post subject: Re: Torque setting for clutch plate screws? Posted: Fri Jul 11, 2014 9:01 am |
last point of the torque overview in the workshop manual: Clutch control disc fast. screws: 7,8-9,8Nm (5,8-7,2 lb/ft)
Btw if you can`t find one value its worthwile checking the 906, Sport or 907ie manual.
| Top |
fasterdammit
Post subject: Re: Torque setting for clutch plate screws? Posted: Fri Jul 11, 2014 11:10 pm |
1997 Monster 750
| Top |
giocast
Post subject: Re: Torque setting for clutch plate screws? Posted: Tue Jul 15, 2014 2:58 pm |
Joined: Sat Sep 18, 2010 8:00 pm Posts: 136 Location: UK
Hope I caught you in time - I don't know which bike you have, but you hinted at the best approach as these screws are a candidate for overtightening and the threads on the 6 posts are often close to being stripped. Using a torque wrench at such low figures is questionable even if it's a high quality one as it's still possible to overtighten the fixings. It's much better to 'feel' all 6 up by hand with both screw and tapped post totally dry of all lubricant if possible. It's impossible to convey accurately but as an approximate guide you should just be able to turn the engine over (plugs out) when tightening.
| Top |
fasterdammit
Post subject: Re: Torque setting for clutch plate screws? Posted: Tue Jul 15, 2014 8:30 pm |
Yeah, I figured they wouldn't need to be honked on too much, since they each have a spring putting negative pressure against them through the plate, making the plate act a bit like a lock ring. (Also, I've got an '88 Paso 750)
Thanks!
1997 Monster 750
| Top |
Derek
Post subject: Re: Torque setting for clutch plate screws? Posted: Wed Jul 16, 2014 9:20 am |
Not much pressure at all. The spring posts snap off very easily.
| Top |
[ 6 posts ] |
Users browsing this forum: No registered users and 8 guests |
