ducatipaso.org • View topic - trick anyone?
It is currently Wed Oct 28, 2026 9:47 pm
 Post subject: trick anyone?
PostPosted: Wed Jul 16, 2014 8:55 pm
I've found a good set of 10:1 pistons with matching cilinders. Done approx 14k kilometers. Only problem is I don't know which piston was used in which cilinder. Is there a way to find out? Or is replacing the rings the only solid option?
Léon
 Post subject: Re: trick anyone?
PostPosted: Wed Jul 16, 2014 11:25 pm
measure and match wear marks or just watch the leftie for a while :lol: :lol: :lol:
PostPosted: Thu Jul 17, 2014 1:20 am
Why put used, mismatched parts in your bike? Unless the parts are unavailable, I would hone it and put new rings on the pistons if they measure out correctly. All that hassle to build a pokey smoker. :banghead:
PostPosted: Sun Jul 20, 2014 9:00 pm
You're right if this isn't possible. It's all about reducing costs if possible. Got more projects I'm working on ;)
Léon
PostPosted: Mon Jul 21, 2014 12:54 am
Brutus, I guess in a perfect world you would fit new rings and all that other " more money than brains" stuff, but I bet if you just pick a piston and rings , stick them in one of the cylinders , same for the other, assemble as usual and start er up , and you wont be able to pick the difference from new parts . 14k is just run in and it would be a waist to not use those parts somewhere.
There are people out there that will wank on about only using new original parts, fitted in surgically clean workshops , and look down their ( large red ) noses at anything that's not factory or correct.................a lot of these Dicks hardly ride their bikes ... if at all, in the real world :) . Not something I have noticed here............um , if you have an RD400 you probly know what I mean :lol: :lol:
PostPosted: Mon Jul 21, 2014 12:16 pm
PostPosted: Mon Jul 21, 2014 12:56 pm
model: other
[quote="Mc tool"if you have an RD400 you probly know what I mean :lol: :lol:[/quote]
Possible thread hijack which someone will delete if needed, but what the F@!#*, so how is the holey piston RD project coming along anyway? :shock: :rimshot:
Himself :drunk:
PostPosted: Mon Jul 21, 2014 6:14 pm
PostPosted: Tue Jul 22, 2014 6:03 am
PostPosted: Tue Jul 22, 2014 11:06 am
PostPosted: Wed Jul 23, 2014 4:38 am
PostPosted: Wed Jul 23, 2014 10:24 pm
model: other
PostPosted: Sun Jul 27, 2014 6:12 pm
By the way, I can see some kind of "MP" logo impressed in my vertical cilinder, close to the belt cover. Is it standard or do I have big bore too?
PostPosted: Wed Jul 30, 2014 7:59 pm
PostPosted: Thu Jul 31, 2014 7:41 am
