ducatipaso.org • View topic - mikuni running rich..
It is currently Fri Jun 19, 2026 9:52 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: mikuni running rich..
PostPosted: Fri Jul 25, 2014 8:02 am
we`re all missing some info here. The carb is from Phil so I`m assuming it originally came from a 900. Did it come with a Dynojet kit or not ? Another difference between the 750 & the 900 jetting (except to the pilot jet) is the needle jet. Y-6 vs. Y-2.
What happens if you turn the pilot screws in. Does the engine stall, does it not or doesn`t it react at all ?
PostPosted: Fri Jul 25, 2014 12:22 pm
I have the needle jet written down, but can't remember what one.. yeah it will stall out or choke up if it's under 2 turns... I am ritchening the mixture by turning the screw out correct? Dunkin jet needle is the only part not mikuni
PostPosted: Fri Jul 25, 2014 6:48 pm
Base set up is 2,5 turns out. 4,5 is a lot.
PostPosted: Sat Jul 26, 2014 2:39 am
Needle jet is a y-2
PostPosted: Sat Jul 26, 2014 11:59 am
that`s the one for the 900
PostPosted: Sat Jul 26, 2014 4:42 pm
Gotcha, I did drop back down to the 130 jet that was in it, and it didn't like the 35's so went back up to the 37.5 and am 2.5 turns out and it seems to be running smoothly. Still sputtering as soon as my needle starts to play in... This could be my needed jet being to large? I am at 4500 feet so my jetting will be leaner than most
PostPosted: Sat Jul 26, 2014 9:54 pm
I don`t know why the 900 uses a Y-2 and the 750 a Y-6.
The Y-2 is leaner as the Y-6.
The later in the alphabet the larger the diameter of the needle jet.
From one letter to the next (with the same number; i.e. Q-2 to R-2) is 0,05mm difference.
From one number to the next (with the same letter; i.e. R2 to R3) is 0,005mm difference.
I found this german file which shows it, too. Based on the table at the bottom of p.1 the Y-2 is 3,11mm diameter, the Y-6 is 3,130mm.
https://app.box.com/s/a0aktvn8cj2nmp059sa8
Generally I would always start with a known/standard setup i.e. the one of the 750SS and go from there.
But that`s me. I personally find it more difficult to start off with something already modifyed (in this case a Mikuni with a pilot jet from a 750, the needle jet from a 900 and an unknown aftermarket needle). Of course you would need a leaner jetting for the altitude you`re living at but on the other side you don`t have an airbox, but you`re using UNI pod filters and have (what seems to be) a Two Brothers exhaust which will make carburation leaner. The effect of the altitude could be equalized by filters and exhaust or maybe their effect is stronger than the thin air.
PostPosted: Sun Jul 27, 2014 1:13 am
I am not sure on the exhaust brand, I have looked at it but can't remember.. it seems to be running good, still not idling as well as I would like.. I still have symptoms of a vacuum leak but there is none..
When it is warmed up completely the idle will hang about 1000 rpms higher but I can't find the middle ground. It's either to lean or to rich
PostPosted: Sun Jul 27, 2014 10:02 am
if the idle is high, you can`t lower it and you`ve verified there are no airleaks I`d say the carb is running lean. Noone else have an opinion ? :)
PostPosted: Sun Jul 27, 2014 11:28 am
PostPosted: Sun Jul 27, 2014 3:25 pm
That is a possibility, the needle jets do show some wear..
PostPosted: Mon Aug 04, 2014 6:47 pm
as said somewhere above it's worth not only confirming that you have original needles (operated via diaphragms) but that you also have original return springs (not the weaker Dynojet versions) plus the equivalent jets for above needles aren't worn (usually becoming oval instead of round on inspection) as any/all of these can contribute to the initial stumble and splutter on pick-up that you mention on a 'sensitive' engine.
PostPosted: Tue Aug 05, 2014 7:37 pm
the needles and springs are new dyno jet.. i think new needle jet( e tube) will smooth it out if them being worn can cause rich spots. everything else on these carbs has been meticulously inspected multiple times for possible damage or wear..
the bike is pretty happy at its current setup, running just a tad lean when cold but just right when the engine has heated up.
PostPosted: Sun Aug 10, 2014 3:55 am
With my fuel line, I just have a tee fitting to the carb then to the tank. I almost feel its not getting enough fuel into the carbs under heavy load situations.. input?
PostPosted: Tue Aug 12, 2014 3:28 am
150 dyno jet installed, carbs vacuum synced... Status... MONSTER!.... I think one more step up on the main jets will be perfect
