It is currently Fri Jun 19, 2026 9:44 am
Post new topic Reply to topic  [ 470 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 32  Next
PostPosted: Fri Jul 25, 2014 7:02 am
model: other
PostPosted: Fri Jul 25, 2014 8:14 am
I only got them because of your insistence Peter :lol: .I wasn't happy with the result from painting the instrument support frame so I've repainted it.Sooo nothing exciting to report tonight.I think I'll tackle this and the sidestand tomorrow.
Andrew
PostPosted: Fri Jul 25, 2014 9:51 am
model: other
PostPosted: Fri Jul 25, 2014 10:23 am
That is different.It looks like you get a better air flow to the regulator.I wonder if the previous owner cut the tray or it came from the factory like that.I might look into either drilling some holes into the front of the tray or cutting it back like yours.
Andrew
PostPosted: Fri Jul 25, 2014 12:21 pm
model: other
Hmm, interesting......
What was it about parts bin special they said :shock:
PostPosted: Fri Jul 25, 2014 3:02 pm
Peter`s tray isn`t cut. It`s just that he has removed the crankcase breather tank. At least that is how it looks.
PostPosted: Fri Jul 25, 2014 8:01 pm
model: other
PostPosted: Fri Jul 25, 2014 10:03 pm
PostPosted: Fri Jul 25, 2014 10:21 pm
In my opinion, the Crankcase breather is well worthwhile to keep in place. its designed as a Helmoltz resonator and helps to get gasses out of the engine better than the open breather right off the crank. If you put on an aftermarket shock though, you won't be able to fit the stock breather tank, as the spring coil is much wider than stock. I have tried many ways to do that, and have no good solution. Ended up with a long 1" ID stiff tube to the back with a Bunn Breather one way valve on the end. Actually helps on the top end.
PostPosted: Fri Jul 25, 2014 10:25 pm
PostPosted: Fri Jul 25, 2014 10:51 pm
PostPosted: Sat Jul 26, 2014 12:19 am
model: other
I've no idea what it ran too from the Digiplex, something to do with the Fuel Injected models or the webber or some such? vaguely remember reading something here on the site but old age has kicked in. :lol:
Did wonder when ever the seat unit was off it, but it ran fine and never worried about, whoever did the Keihin conversion in Japan seemed to know their stuff, so had tried to leave most things alone on it, barring the wheels/brakes/fairing of course......
Now get back to the shed :D
Peter
PostPosted: Sat Jul 26, 2014 12:30 am
Looks like a nice Summer (and Winter also if you work as slow as I do) project. Have Fun. It looks like a Learning Experience.
RB
PostPosted: Sat Jul 26, 2014 12:48 am
The vacuum hose that goes to the Digiplex, should be connected to the barbs on the intake manifolds. If everything still works, this is a vacuum advance. Helps most on the top end. With my original Digiplex box, the vacuum advance did not work anymore. I bought a new one from Ian in Oz, and it surely found a few more ponys on the top end. I ran a "T" and tapped into both intake manifolds, and ran all fresh lines to eliminate any leaks.
PostPosted: Sat Jul 26, 2014 2:34 am
