ducatipaso.org • View topic - Paso thrown to the floor....
It is currently Sat Jun 13, 2026 3:11 am
 Post subject: Paso thrown to the floor....
PostPosted: Thu Aug 07, 2014 4:23 pm
I was hurrying to put my Paso into the garage, and it happened that my right leg was not long enough. I still try to b not annoyed (one day before holliday) but without success....
Damage:
-Mirror broken (No problem, have enough.. just need let paint one)
-Windshield broken on the right side (SHIT!!!!)
Even it's not that bad I'm not certain if this need mayor repair.
If i could press the two pieces together and put Araldite in between, it would probabely not look to bad. But i'm not sure if this fix works.....
Any of you guys experienced in fixing polyester?
Any Good advise?
Best repair product?
Tnk's
pasoalf
Paso 750/ 1987
Paso 906/ 1992
 Post subject: Re: Paso thrown to the floor....
PostPosted: Thu Aug 07, 2014 9:27 pm
any good 2 part epoxy works great :thumbup:
PostPosted: Thu Aug 07, 2014 10:14 pm
PostPosted: Thu Aug 07, 2014 10:31 pm
PostPosted: Fri Aug 08, 2014 2:02 am
Bummer!
+1 on the polyester resin.
PostPosted: Fri Aug 08, 2014 7:16 am
PostPosted: Fri Aug 08, 2014 7:23 am
fixing it with poly resin is no problem. But that won`t work w/o having to repaint the whole part after. Specially the damage shown on the last photo can`t just be "glued" back together as the fibres are torn out of their meshwork and you won`t be able to join both parts perfectly w/o the edges standing over.
PostPosted: Mon Aug 11, 2014 4:05 am
PostPosted: Wed Aug 13, 2014 4:15 pm
Fiberglass can be repaired but it has to be done with fiberglass. As previously noted the fibers have been pulled and broken and at first it looks impossible. A professional will use a hacksaw blade and carefully saw into the split to sever all the loose fiber, closely following the contour and path of the split. So making it a clean split, without fiber strands. Then fill with fiber resin to rejoin the panel. It sounds impossible but it is quite easy to do and have a near perfect repair.
PostPosted: Wed Aug 13, 2014 8:01 pm
It is permissible to use tape and plasterscene ( modelling clay that doesn't set hard ) to make small dams to contain the fiberglass resin ( polyester ) until it sets. I use aluminium tape which has the strength to hold parts in position and contain resin . If you do it right you can follow the contours of the original body work saving reshaping work. If you use the hacksaw method above , and the strong tape a surprisingly presentable repair can be had at the 1st stage. It does pay to heed the advice ( on the container )regarding ambient temp as if its to cold the stuff takes ages to set ... and then not that well . :)
Users browsing this forum: No registered users and 114 guests
