ducatipaso.org • View topic - Sprocket carrier bearings
It is currently Wed Feb 25, 2026 10:40 am
 Post subject: Sprocket carrier bearings
PostPosted: Thu Aug 14, 2014 4:28 pm
Found that my carrier bearings are shot. How does one get the bearings out? I don't want to ruin my sprocket carrier. :banghead:
Thanks!
 Post subject: Re: Sprocket carrier bearings
PostPosted: Thu Aug 14, 2014 5:21 pm
The two bearings sit (with a spacer between them) in a steel sleeve that`s pressed into the sprocket carrier. The bearings can only be pressed out to the front side. The things to watch out for is to support the steel sleeve in the front and not the sprocket carrier as you dont want to press out the sleeve and if you apply pressure from the rear side of the sprocket carrier to do it on the bearing not on the steel sleeve.
For the reassembly put the bearings in the freezer over night and clean the sleeve then the bearings will slide in easier. It shouldn`t be necessary to mention but I`ll do it anyway. Do not use a BFH when working with bearings.
PostPosted: Thu Aug 14, 2014 11:31 pm
Thanks a lot!!
When you say front side, do you mean the sprocket side?
Doing a search, I found this bearing # SKF-6005-2RS1/C3, is this correct?
No worries, no BFH used. :lol:
Thanks again for your help,
Mick
PostPosted: Fri Aug 15, 2014 8:09 am
yes and yes. You`ll see when you turn the sprocket carrier around that the steel sleeve has a flange on the rear. So there`s no getting them out and back in on this side.
PostPosted: Fri Aug 15, 2014 12:26 pm
Thanks again for taking the time to answer my questions. :beer:
I want to get my new Shinkos mounted up and see how they work. :thumbup:
PostPosted: Mon Aug 18, 2014 1:03 pm
Put the complete assembly in the oven at a low heat for half an hour. Aluminium expands more than steel. Then, wearing a thick workshop glove, hold the ass'y in your left hand. Place a large socket over the bearing and give it a hefty whack with a hammer. It will move. I have never found the freeze method to work, only the heat.
PostPosted: Mon Aug 18, 2014 7:59 pm
PostPosted: Tue Aug 19, 2014 2:10 pm
Heat helps because anyhow bearing have a very little movement inside their seat. Hammer & punch or using an hydraulic press will do the job
PostPosted: Tue Aug 19, 2014 8:20 pm
Bfh
PostPosted: Wed Aug 20, 2014 3:41 pm
PostPosted: Wed Aug 20, 2014 4:26 pm
Another "hand job" from J :lol: :lol: :lol:
PostPosted: Thu Aug 21, 2014 9:18 am
PostPosted: Fri Aug 22, 2014 12:09 am
Still waiting for the bearings to arrive.... :toetap:
PostPosted: Tue Sep 09, 2014 2:51 pm
Thanks to all for the info! The bearings pushed right out and the new ones pushed right in.
Now to try out these new Shinkos. :choo:
One thing to watch out for mounting these tires, the little rubber stringy things on the bead made it leak around the rim, so I had to break the bead and trim them off to get a good seal.
Users browsing this forum: No registered users and 43 guests
