ducatipaso.org • View topic - WTB Any parts for 907ie.
It is currently Sun May 03, 2026 11:18 pm
 Post subject: WTB Any parts for 907ie.
PostPosted: Tue Oct 28, 2014 4:59 pm
I am looking to obtain spares for my 1991 907ie. Items I am interested in include larger 320mm discs and calipers from a 1992 model, any carbon slip on mufflers, euro tail light, turn signal lenses, any rubber items.
I will entertain buying most anything, especially new oem items.I plan on keeping this bike a long time and have been updating it since i got it. Thanks,Russ
 Post subject: Re: WTB Any parts for 907ie.
PostPosted: Tue Oct 28, 2014 9:22 pm
If you use Ebay keep searching the European lists as you may see what you are after if you are lucky. Any issues re postage let me know and if I can help with a transit address over here I will happily assist.
PostPosted: Tue Oct 28, 2014 11:01 pm
PostPosted: Sun Nov 02, 2014 5:19 pm
The 320mm rotors are plentiful, as they are the same as almost all Ducati, Aprilia, Moto Guzzi and more through the 90's. If you have the 300mm rotors now, changing is not as easy as swapping rotors. You need to change either the bottom fork legs or make adapters. The calipers for the 320 and 300 are the same. Its the location of caliper mount tabs on the fork legs that determines 300 or 320mm rotors can be run. If you are looking for more braking force, upgrading to cast iron and nice pads will get you a lot more, and better than stock 320mm rotors.
Of course braided lines will help a lot too.
