ducatipaso.org • View topic - 907i.e. tach problems
It is currently Tue Oct 27, 2026 5:55 pm
 Post subject: 907i.e. tach problems
PostPosted: Sun Nov 02, 2014 3:53 pm
My tach suddenly stopped working. Occasionally dribbles up to 1000 rpm at best. Does anyone know any simple diagnostics for one of these? if it's kaput, I'm looking for one--will an earlier 906 or 750 Paso tach work?
Thanks,
Bob
 Post subject: Re: 907i.e. tach problems
PostPosted: Sun Nov 02, 2014 5:06 pm
Start with the cable. Like the speedo, its a spinning cable inside housing. If they get a bit dry, they will seize up and twist off. There is a ferrel on the top side to help support the inner cable and be a bearing. Like the speedo cable and speedo drive, they are often neglected an need some lube from time to time.
I just put one on my bike and the inner cable was really dry. I used some motor oil on it.
PostPosted: Sun Nov 02, 2014 10:16 pm
Hi, had similar symptoms on mine, turned out the gears in the head was worn out, parts 13 in this pic:
