ducatipaso.org • View topic - Big bore or OEM?
It is currently Tue Oct 27, 2026 1:30 am
 Post subject: Big bore or OEM?
PostPosted: Mon Nov 10, 2014 4:47 pm
During last service I realized I have an unusual logo impressed in both the cylinders: It might be a "mondial piston" sign but I don't know whether they're OEM pistons or an aftermarket Big Bore.
Can someone have a look to his engine and tell me if matches the sign?
 Post subject: Re: Big bore or OEM?
PostPosted: Fri Nov 14, 2014 4:12 pm
55 Views and no answers...
PostPosted: Fri Nov 14, 2014 8:24 pm
I was sure I have seen these before, so I checked and I can confirm they are 100% standard.
My special has a 750 engine and my barrels were standard bore.
Mondial Piston does (did?) also alloy casting, there aren't many in Italy so is not surprising to know they were one of the "elected"
I am preatty sure there were others, Ducati always had several suppliers for the same item.
PostPosted: Fri Nov 14, 2014 8:48 pm
Mondial is now part of Mahle has been since 1987
PostPosted: Sat Nov 15, 2014 5:12 pm
Yes, I know about that and it makes harder to find infos about such pistons just for the years of change.
PostPosted: Sun Nov 16, 2014 2:00 am
PostPosted: Mon Nov 17, 2014 8:28 am
Update: I just received a mail about the question: These are OEM cylinder and Mondial Piston was not the only supplier for Ducati so you can happen to have or not the logo on your engines... Ok, Now I know that Dukess runs fine not because of 780cc breath!
