It is currently Mon Jun 15, 2026 4:22 pm
 Post subject: rear turn signals
PostPosted: Fri Nov 28, 2014 4:06 pm
Hi Guys, I was wondering if anybody has found a alternative rubber turn signal stalk for the rear that will work and look ok from 10 ft. away? Two of my 907's have problems in that one is cracked all the way through and the others sag quite a bit with cracks which means its just a matter of time. In my last year of searching I've only found one on e-bay. Most of the ones from later Ducs are very short but may have to go to that. Also was wondering if any of our Italian friends on the forum have ever checked with the maker of the front lens as to a possible run of of those since they also seem to be very hard to come up with. Thanks Archie.
 Post subject: Re: rear turn signals
PostPosted: Fri Nov 28, 2014 4:51 pm
If you like turn signals with long stalks I`d have a look at jap bikes. Many bikes use short ones on the front and long ones in the back. Most look more modern than those large square ones from the Paso and will probably look better on the bike.
i.e. Yamaha XJ900
PostPosted: Sat Nov 29, 2014 2:12 am
Check this site out:
http://www.stein-dinse.biz/Ducati/Elect ... 2_670.html
Users browsing this forum: No registered users and 26 guests
